20 Most Recent Kenwood RC-R0720 Remote Control Questions & Answers
Call 1 888 TW CABLE To Place Your Order For Time Warner Cable Service Wich Is The Best And Allways Will Be!
I Don't Know If They Will Still Buy You Out Of Your Contract Or Not So You Will Have To Ask!
Direct TV And DISH NETWORK Are Both SCAMS And You Fell For One Of Them ! They Are Ripping You Off!
Kenwood RC-R0720... | Answered on Nov 25, 2014
CODES FOR REMOTE R MOB ILE
Kenwood RC-R0720... | Answered on Jul 10, 2014
YA WHY NOT , THIS PROBLEM PERSISTS DUE TO WATER , IF U CAN REMOVE D TOP COVER OF UR REMOTE N CLEAN IT WITH A COTTON WITH OUT USING ANY THING N RE COVER IT N USE IT UR PROBLEM IS SOLVED
This remote control have no setup codes to Kenwood. If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check out, which brand remote control has setup codes to your TV/Device brand. Setup code list & setup procedure to some popular brand remote controls are given. Check it, and determine which brand remote control should be bought, and buy that brand remote control, according to availability. If you wish to get more details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy.
Kenwood RC-R0720... | Answered on Nov 04, 2013
Here it is!
http://remotes.com/remotes/documents/Kenwood/RC-R0720.pdf
Page 35 if I'm not mistaken.
Good Luck!
Kenwood RC-R0720... | Answered on May 23, 2013
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1400 posts to different brand TVs now. Pull up older posts there or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
Kenwood RC-R0720... | Answered on Dec 10, 2012
If you have a Kenwood receiver and a Kenwood remote, does it have a receiver button (RCVR)? If so you should not need to do any programming
Kenwood RC-R0720... | Answered on Nov 30, 2012
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 4 of the manual in Section 32 - SEARCHING FOR YOUR CODE for detailed instructions on how to auto search for the correct code to program your device for a particular component.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Kenwood RC-R0720... | Answered on Nov 30, 2011
I have only the genaral rule, I dont know the particulars.
Kenwood used to have preset passwords as 1234
pressing the stop button ( if you have one ) for 30 seconds.
As i said these are general rules for reseting but I'm not familiar with your model
( buy Yamaha )
Kenwood RC-R0720... | Answered on Feb 23, 2011
I had the same problem, and the solution above/below that says to use code 018 worked for me. Yeah!!!
Kenwood RC-R0720... | Answered on Feb 03, 2010
When using what kind of a Machine???
Kenwood RC-R0720... | Answered on Aug 30, 2009
The problem has nothing to do with the television. To fix it, simply change the remote address. The directions for this are in the Dish manual, or you can check it out on the website here: http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/622.shtml
Hope this helps.
Kenwood RC-R0720... | Answered on Aug 13, 2009
I don't know about the 612 but the 722 I have has green tabbed control for IR control of output 1 and by default of tuner 1 and controls the OTA tuner and will work with many IR remotes if set to address 1--they don't send the address. The blue tabbed one is for RF-controlled output 2 and tuner 2. Setting it to single (vs. dual) mode allows either remote to control tuner 1 and swap to tuner 2 and do PIP. Unfortunately the 612 does not have this mode.I haven't had a combo remote work well with tuner 1 even. It is much better to use the Dish remote for most of the work, well only volume and power on the TV. There are a lot of buttons most combo remotes will not have control of. Hey, I have 2 VIP722 and the TV remotes on the chair arm.Check with menu-menu to see which address code and control mode is set. But if manual allows and you can pull tab after opening battery slide and change switch beneath, you may be able to use as IR remote in preparation for your combo, just to be sure controls sent correctly. (Hold Sat button until all light, press address 1, press # to set remote [lights go out], then press record to set receiver while you watch menu-menu. less than 10 sec per step.)-Ken
Kenwood RC-R0720... | Answered on Jul 15, 2009
remte control lost codesa
Kenwood RC-R0720... | Answered on May 15, 2009
Searching for your code press the tv key once, Next press and hold the set up key until the led blinks twice, then realease the set up key.
Now press numbers 9-9-1 the LED should blink twice
Point the remote at the tv and slowly alternate between pressing the power and tv keys stop when tv turns off. Now this is based on the information if it is a Kenwood remote RC RO720... if not may I get the make and sat info and may be more helpful to you....Thank you
Kenwood RC-R0720... | Answered on Feb 06, 2009
here is webiste for you to go to that might help you reprogram your remote:
http://remotes.com/store/codes_original.html
Kenwood RC-R0720... | Answered on Dec 18, 2008
Televison & Video Logo
Popular Tags
29 questions posted
Top Kenwood Televison & Video Experts
Ekse
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Televison & Video
Most Popular Question
get toshiba ct 90302 program
  • Televison & Video
