20 Most Recent
HEWLETT-PACKARD Photosmart D7460 InkJet Printer Questions & Answers
0xc18a0206
Hi Richard,There are few troubleshooting steps that you can perform to fix this issue. This issue is related to Printhead Failure ( that holds the cartridges )
1. Disconnect the Power cord from back of the printer ( printer must be power on when you do this )2. Wait for 10 seconds and plug the cable to Printer3. Wait for the printer screen to display the menu4. Try to print test page.Or Try the Step Below
This is easily fixed with the following key sequences. You do NOT have to open the printer and unplug a circuit board.1) press * and # at the same time2) press 1, 2, 3 and "support R0632M" should display3) press > and "information menu" should display4) press > and "configuration menu" should display5) press OK and "hardware failure status" should display6) press OK "failure status: clear". Press OK to clear7) press CANCEL8) press CANCEL9) press CANCEL10) turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.NOTE: I did this and the fist time the error came back. Do the sequence again (as I did) and the error will be replaced with the usual print cartridge initialization screens. Print a test page to make sure. ORCheck this link as well for more detailed information ->
Click here
Hp laserjet 5100n
Go to the hp.com site and search for said driver. Sometimes they do not update their drivers for older machines, but I am not familiar with this one. Good luck. Once a year Staples will have a special where one can trade in an old machine for a discount on a new HP.
HP Laser printer USB connector broken
What model? Connector on the outside or on the mainboard? If on the mainboard, replace it. If on the front, you should be able to just replace the connector cable and/or mounting.
Cannot receive fax
make sure you have a phone line plugged in correctly (into the in plug) and set the printer / fax to recieve auto. Do not pick up the phone while recieving the fax, If thei does not work, check your setting in the software.
Hp f4435
I'm assuming you have the correct drivers loaded and correctly configured.
Set power switch to off.
Unplug it for 1 minute.
Plug it back in.
Turn it on.
If it still won't work, I suggest replacing the power supply.
If it still won't work, I suggest you replace it.
Laserjet p1320
Hi
This printer should have problems with the fuser unit or the power supply
