20 Most Recent Celestron PowerSeeker 60 EQ (675 x 60mm) Telescope Questions & Answers
Need instructions for a powerseeker 675
All of Celestron's manuals are on this web site:
http://www.celestron.com/c3/downloads.php
3/21/2011 4:56:26 PM • Celestron... • Answered on Mar 21, 2011
Where can i find a
Eyepieces come in THREE sizes: .965, 1.25, and 2 inch. Measure the hole in the telescope.
Many on line retailers sell eyepieces. Here are two:
http://www.agenaastro.com/
http://www.telescope.com/control/telescope-eyepieces
9/24/2010 2:10:51 PM • Celestron... • Answered on Sep 24, 2010
2answers
Focus knob turns but nothing moves
The Celestron manual for this scope has nothing to say, but on the underside of the focuser assembly, between the 2 focus knobs, you may see 2 screws.They might be thumbscrews or some other screwhead type. One is the adjustment for the focuser internal clearance, or looseness, and the other is a focus travel lock.If present, try backing both off 1/2 turn from tightness, and then experiment to see which is which. The focus lock will have no effect until tight, when the focuser will cease moving, as is now. The other screw will gradually remove looseness and rattle from the focuser until it just moves smoothly, with no back and forth loose feeling at the knob.If neither of these screws is visible you will have to take it to a binocular and telescope shop, where they should not charge much.
12/7/2021 2:09:26 AM • Celestron Optics • Answered on Dec 07, 2021
How to clean Celestron binoculars 15x70 lenses inside?
topbestjob.com
9/15/2020 3:08:57 PM • Celestron Optics • Answered on Sep 15, 2020
Battery size telescope celestron 114
Why not look at the old battery, or look in the manual ?
11/28/2019 12:20:02 PM • Celestron Optics • Answered on Nov 28, 2019
What is the weight of the celestron next star se 8
It is impossible to assess the weight (or more correctly Mass of a star, as weight is a perceived function of Earth's gravity) without knowing the chemical make up of the star. That is why astronomers use the star's measured albedo to qualify and quantify them.
9/16/2019 6:23:17 PM • Celestron Optics • Answered on Sep 16, 2019
How to use a celestron powerseeker 127EQ
Read the manual. Follow the instructions therein.
6/13/2019 9:27:53 PM • Celestron Optics • Answered on Jun 13, 2019
Hello i have a celestron astro fi telescope and it will not align correctly it seems to point to the ground even when the app is showing the night sky ?? can you tell me what i am doing wrong
You may find you have to aim it at the sky yourself - sounds as if the calibration may be 180 degrees out
12/12/2018 10:52:29 PM • Celestron Optics • Answered on Dec 12, 2018
0answers
We have a celestron 114AZ telescope. we cannot see anything with it. why?
Most problems will be overcome by reading and absorbing the instruction manual. Assuming the telescope is in good order, it must first be pointed at a light source using the spotter scope and then aligned using the lowest power eyepiece before fitting the high powered eyepiece... You also should be in very low light conditions.
9/23/2017 5:10:01 AM • Celestron Optics • Answered on Sep 23, 2017
Celestron NexStar 5 SE telescope has no power
Do you mean resolving power or magnification power ?
9/1/2017 10:00:11 AM • Celestron Optics • Answered on Sep 01, 2017
2answers
I have a pair of OCEANA 7X50 waterproof binos that
Please do so
6/26/2017 5:39:21 AM • Celestron Optics • Answered on Jun 26, 2017
Celestron PowerSeeker 60 EQ (675 x 60mm) Telescope Logo
Popular Tags
2 questions posted
Top Celestron Optics Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Celestron Optic Expert? Answer questions, earn points and help others
View Most Popular
Celestron Optics
  • Celestron Optics
Most Popular Question
need instructions powerseeker 675
  • Optics
