20 Most Recent Kenwood KR-A5080 Receiver Questions & Answers
Standby mode, shuts off
After 10 years of use probably best to replace with a new unit. Most will be hard to find exactly wich little bit is broke.
5/23/2017 2:57:53 AM • Kenwood KR-A5080... • Answered on May 23, 2017
0answers
How do you program the preset radio station
Found the instruction manual for your model here:
http://kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/kra5080.pdf
Hope this helps.
12/10/2009 9:41:22 PM • Kenwood KR-A5080... • Answered on Dec 10, 2009
Protect
transistor amplifier short ..need replaced
11/15/2009 7:28:48 PM • Kenwood KR-A5080... • Answered on Nov 15, 2009
2answers
Same problem with KR-A46
Hi all,
may I ask if anybody solved the station memory problem
with Kenwood KR-A46. I do have the same and I dare to fix it
but I am looking for the right solution.
Thanks!
Ralf
9/4/2008 7:59:00 AM • Kenwood KR-A5080... • Answered on Sep 04, 2008
2answers
Station Preset Memory Lost When Power Off
Have same unit, exactly the same problem: station presets lose setting when power is off. I've opened the unit; there is no apparent battery of any kind.
As long as the unit is powered up, the station pre-sets seem to hold. There IS a capacitor across the power switch. Some A/C will therefore be transmitted into the unit when plugged in, even with the switch off. If the capacitor is open, no charge will enter the unit when the power switch is open. I will probably replace this capacitor and see if that fixes things, but it may take several days to do so. Has anyone else tried this?
9/4/2008 6:48:35 AM • Kenwood KR-A5080... • Answered on Sep 04, 2008
I have a kenwood T58 L tuner connected to A58 amplifier. I tried to tune the tuner, but all in vain. Can any one provide me the owners manual for T 58L tuner?
The user manual is available here:http://www.kenwood.com/i/idc/files/english/pdf/T-58L_EN_01.pdf
11/23/2022 9:30:00 AM • Kenwood Audio... • Answered on Nov 23, 2022
My Kenwood VR-615 Power light is blinking
Hi, there might be a power-related part that needs to be upgraded. Please check the table of contents of the manual for errors or troubleshooting section to identify what procedure needs to be followed to get your kenwood working again. Thank you.
11/11/2022 3:39:50 AM • Kenwood Audio... • Answered on Nov 11, 2022
Kenwood KR-V7080 receiver. No sound from rear speaker amp connections
Hi, please check the wires of the speaker for damage. If interchangeable with the other working speakers, please temporarily swap them at check if the good speakers continue to work. If so, then you would need to most likely get the rear speaker replaced or repaired. Thank you.
11/11/2022 1:37:16 AM • Kenwood Audio... • Answered on Nov 11, 2022
I Need a manual for kenwood CD player model DP-R28
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwi36e2nmOr6AhUtjYkEHalDBwgQFnoECBYQAQ&url=https%3A%2F%2Fwww.ebay.com%2Fitm%2F123879892191&usg=AOvVaw1YafJVS_gAjMQ39KBlp7mo
10/18/2022 4:24:13 PM • Kenwood Audio... • Answered on Oct 18, 2022
Where can I locate a Kenwood turntable tonearm assembly for model KD492F
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiUgaHBl-r6AhWkj4kEHSBNB8AQFnoECA8QAQ&url=https%3A%2F%2Fwww.ebay.com%2Fb%2FKenwood-Record-Tonearms-Parts%2F64619%2Fbn_11821709&usg=AOvVaw3gPElGbTY_LZponZwKWxyO
10/18/2022 4:20:41 PM • Kenwood Audio... • Answered on Oct 18, 2022
Kenwood kr-v8040 schematics
Kenwood kr-v 80 40 not warking display
10/14/2022 6:17:25 AM • Kenwood Audio... • Answered on Oct 14, 2022
I just picked up this Kenwood V-7030 tuner, by far one of the strongest I've had yet,I was looking at the back ohms setting on here. Can I hook up car audio subs 2 this? newish to home equip. Thanks
This could get complicated. Your safest option is to use home audio subwoofers as that will be a simple plug in and use setup. If you want to run car subwoofers to a mains powered tuner you will need to know what the Ohm rating is for that sub. The Ohms rating must be the same on both the speaker and sub.. Too low and you risk blowing the Amp/Receiver. Too high and you'll get very poor sound. Car audio equipment is also designed to run on 12 volts where Home audio uses 110v or 240v so that can cause issues as well.
8/24/2022 7:07:55 AM • Kenwood Audio... • Answered on Aug 24, 2022
Kenwood KD-72FB Linear Tracking turntable: control arm is skipping across record
sounds like missing weight or needs adjustment
8/21/2022 10:40:52 AM • Kenwood Audio... • Answered on Aug 21, 2022
My kenwood kr v5570 give no sound
look inside see if there are fuses if not possible out puts bad
8/7/2022 7:11:06 AM • Kenwood Audio... • Answered on Aug 07, 2022
Popular Tags
11 questions posted
Top Kenwood Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
David Shaub
Morne Olivier
Morne Olivier
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Audio Players & Recorders
Most Popular Question
same problem kr a46
  • Audio Players & Recorders
