20 Most Recent Kenwood KR-V990D Receiver Questions & Answers
When i turn on my kenwood kr-v990d it powers up for about 2min then shuts down
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be with your output drivers. Please check for short on the outputs fitted for both the channels. Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise which can be a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board. Maybe the protect circuit by itself is shutting off due to a faulty bias or there is a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the amplifier comes out of the protect mode then check for short on the speakers.
10/27/2011 10:15:57 AM • Kenwood KR-V990D... • Answered on Oct 27, 2011
Have a kenwood KR-V990D and can't seem to bring the volume up
kenwood has always showed negative numbers 00 is as high as it will go
1/6/2008 10:49:01 PM • Kenwood KR-V990D... • Answered on Jan 06, 2008
Kenwood, Very little sound for no reason!!
Check all (and I mean ALL) of your front panel buttons. It sounds like someone has pushed the tape monitor button or something like that. Be SURE to turn the volumn down BEFORE you start pushing buttons. Good luck.
1/31/2007 5:37:36 PM • Kenwood KR-V990D... • Answered on Jan 31, 2007
I have a kenwood T58 L tuner connected to A58 amplifier. I tried to tune the tuner, but all in vain. Can any one provide me the owners manual for T 58L tuner?
The user manual is available here:http://www.kenwood.com/i/idc/files/english/pdf/T-58L_EN_01.pdf
11/23/2022 9:30:00 AM • Kenwood Audio... • Answered on Nov 23, 2022
My Kenwood VR-615 Power light is blinking
Hi, there might be a power-related part that needs to be upgraded. Please check the table of contents of the manual for errors or troubleshooting section to identify what procedure needs to be followed to get your kenwood working again. Thank you.
11/11/2022 3:39:50 AM • Kenwood Audio... • Answered on Nov 11, 2022
Kenwood KR-V7080 receiver. No sound from rear speaker amp connections
Hi, please check the wires of the speaker for damage. If interchangeable with the other working speakers, please temporarily swap them at check if the good speakers continue to work. If so, then you would need to most likely get the rear speaker replaced or repaired. Thank you.
11/11/2022 1:37:16 AM • Kenwood Audio... • Answered on Nov 11, 2022
I Need a manual for kenwood CD player model DP-R28
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwi36e2nmOr6AhUtjYkEHalDBwgQFnoECBYQAQ&url=https%3A%2F%2Fwww.ebay.com%2Fitm%2F123879892191&usg=AOvVaw1YafJVS_gAjMQ39KBlp7mo
10/18/2022 4:24:13 PM • Kenwood Audio... • Answered on Oct 18, 2022
Where can I locate a Kenwood turntable tonearm assembly for model KD492F
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiUgaHBl-r6AhWkj4kEHSBNB8AQFnoECA8QAQ&url=https%3A%2F%2Fwww.ebay.com%2Fb%2FKenwood-Record-Tonearms-Parts%2F64619%2Fbn_11821709&usg=AOvVaw3gPElGbTY_LZponZwKWxyO
10/18/2022 4:20:41 PM • Kenwood Audio... • Answered on Oct 18, 2022
Kenwood kr-v8040 schematics
Kenwood kr-v 80 40 not warking display
10/14/2022 6:17:25 AM • Kenwood Audio... • Answered on Oct 14, 2022
I just picked up this Kenwood V-7030 tuner, by far one of the strongest I've had yet,I was looking at the back ohms setting on here. Can I hook up car audio subs 2 this? newish to home equip. Thanks
This could get complicated. Your safest option is to use home audio subwoofers as that will be a simple plug in and use setup. If you want to run car subwoofers to a mains powered tuner you will need to know what the Ohm rating is for that sub. The Ohms rating must be the same on both the speaker and sub.. Too low and you risk blowing the Amp/Receiver. Too high and you'll get very poor sound. Car audio equipment is also designed to run on 12 volts where Home audio uses 110v or 240v so that can cause issues as well.
8/24/2022 7:07:55 AM • Kenwood Audio... • Answered on Aug 24, 2022
Kenwood KD-72FB Linear Tracking turntable: control arm is skipping across record
sounds like missing weight or needs adjustment
8/21/2022 10:40:52 AM • Kenwood Audio... • Answered on Aug 21, 2022
My kenwood kr v5570 give no sound
look inside see if there are fuses if not possible out puts bad
8/7/2022 7:11:06 AM • Kenwood Audio... • Answered on Aug 07, 2022
I have a Kenwood KD72FB
Norman, I don't know if you ever found your belt. I have the same turntable a I just got one at TURNTABLE NEEDLES.COM for $3. Part #SB03.5 It fits perfectly!
7/17/2022 4:08:09 PM • Kenwood Audio... • Answered on Jul 17, 2022
Popular Tags
8 questions posted
Top Kenwood Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
David Shaub
Morne Olivier
Morne Olivier
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Audio Players & Recorders
Most Popular Question
get sub woofer receive signal from
  • Audio Players & Recorders
