20 Most Recent Kenwood VR-205 Receiver Questions & Answers
0answers
I have 2 good qaulity
You're guessing. That is exactly the wrong thing to do. Get the manual.
http://www.retrevo.com/support/Kenwood-VR-205-Receivers-manual/id/480ci174/t/2/
"[D]vd 6 channel input" is for a 6-channel analog input as the name implies. I doubt you even have a source that HAS 6 analog channel outputs.
Speakers are OUTPUTS of the amplifers' speaker posts. Any one can work ANYwhere.
And that bi-wire capability, IF the speakers have it - pretend it isn't there.
8/1/2011 12:48:50 AM • Kenwood VR-205... • Answered on Aug 01, 2011
Hi, I have a problem
test the remote by using the camera in your cell phone...you should see the IR lights flashing when you operate the remote...these kenwood receivers are notorious for having cold solder joints on the IR receiver...resolder joints like this http://mysite.verizon.net/amp68/ or http://home.comcast.net/~jcoxdesigns/Kenwood/index.html
7/28/2011 10:34:54 PM • Kenwood VR-205... • Answered on Jul 28, 2011
0answers
Can I Get a Kenwood RC-R0608 Remote to work with a Kenwood VR-206 A/V Reciever
i WILL BUY YOUR Kenwood RC-R0608 Remote
[email protected]
7/28/2010 3:14:30 AM • Kenwood VR-205... • Answered on Jul 28, 2010
My vr-205 shuts off right after i turn it on and
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Its usually not a fault that you will see unless somethings burnt up. This is solid state electronics and you dont see this stuff go bad. But in the meantime try disconnecting the speakers and see if it still goes into shutdown and at the same time have a dc multimeter attached to the speaker outputs. If the unit comes on and you dont see any DC at all or very very little B+ on both speaker terminal sets then you may have a defective speaker. If you do see dc then thats why the protections comming on so you dont blow out your speakers. If you dont have any equipment or dont have any electronics experience I advise then take the unit to a repair person for an proper check. Good Luck
5/25/2010 11:46:44 AM • Kenwood VR-205... • Answered on May 25, 2010
IPod Connection
I have my ipod hooked through my receiver, what I did was bought a cord that plugs into the place where you put you headphones and on the other end it has RCA jacks and plug up into you AUX and it should work good thats how I listen to my ipod really loud.
7/11/2008 9:44:32 PM • Kenwood VR-205... • Answered on Jul 11, 2008
How to disable Kenwood amp kac8404
To disable the Kenwood KAC-8404 amplifier, follow these steps:
  1. Turn off the power to the amplifier by removing the fuse or turning off the power switch if available.
  2. Disconnect the RCA cables from the amplifier's input jacks and the speaker wires from the output terminals.
  3. Check the connections and make sure they are secure and free of corrosion.
  4. Reconnect the cables and wires, making sure they are properly connected and secure.
  5. Turn the power back on and test the amplifier to see if it is working properly.
If the amplifier still does not work, there may be an issue with the internal components and it may need to be repaired or replaced.
2/26/2023 5:26:20 AM • Kenwood Audio... • Answered on Feb 26, 2023
2answers
Kenwood KR-V8010 receiver. B speakers are not working. A speakers are
If the B speakers on your Kenwood KR-V8010 receiver are not working while the A speakers are working, there are a few things you can check:
  1. Check the speaker connections: Make sure that the B speakers are connected to the receiver properly. Ensure that the speaker wires are connected securely and that the polarity is correct.
  2. Check the speaker selector switch: The Kenwood KR-V8010 has a speaker selector switch that allows you to choose between A speakers, B speakers, or both. Make sure that the switch is set to the B speaker position.
  3. Check the speaker impedance: Make sure that the impedance of the B speakers is compatible with the receiver. The Kenwood KR-V8010 supports speakers with an impedance of 4 to 16 ohms. If the impedance of the B speakers is too low or too high, it can cause issues with the amplifier.
  4. Check the volume level: Make sure that the volume level is not set too low for the B speakers. If the volume level is too low, it may not be noticeable that the B speakers are not working.
  5. Check the output settings: The Kenwood KR-V8010 has a few output settings that can affect the sound output. Make sure that the settings for the B speakers are not muted or turned off.
If none of these steps resolve the issue, there may be a problem with the amplifier or the B speaker output circuit. In this case, it may be necessary to take the receiver to a professional for repair or maintenance.
2/20/2023 8:48:29 AM • Kenwood Audio... • Answered on Feb 20, 2023
Connecting Kenwood vr-405 to ps4
o connect a Kenwood VR-405 to a PS4, you will need to use the audio and video outputs on the PS4 and the audio and video inputs on the Kenwood VR-405. Here are the general steps to follow:
  1. Connect the HDMI cable from the PS4 HDMI Out port to the HDMI In port on the Kenwood VR-405.
  2. Connect the audio cable from the PS4 Digital Out (optical) port to the Optical In port on the Kenwood VR-405.
  3. Turn on the Kenwood VR-405 and set the input to HDMI or Optical, depending on which cable you used.
  4. Turn on the PS4 and adjust the audio settings on the PS4 to output audio through the HDMI or Optical connection.
  5. Adjust the audio settings on the Kenwood VR-405 to match the audio settings on the PS4.
It is important to consult the user manual of both the Kenwood VR-405 and the PS4 for specific instructions on how to connect them and adjust the settings. If the VR-405 doesn't have a HDMI input, you can use an HDMI to composite adapter to connect the PS4 and the VR-405.
1/25/2023 5:18:49 PM • Kenwood Audio... • Answered on Jan 25, 2023
Kenwood Kr v KR7060. Play only one speaker
If your Kenwood KR-V7060 receiver is only playing sound through the center speaker, it could indicate a problem with the receiver's internal audio processing or speaker configuration settings. Here are a few things you can try to troubleshoot the issue:
  1. Check the speaker configuration settings. Make sure that the receiver is set to play sound through all speakers, and not just the center speaker. You can check this in the receiver's menu or by consulting the user manual.
  2. Check the speaker wire connections. Make sure that all the speaker wire connections are tight and secure, and that there are no loose wires or frayed connections.
  3. Check the balance and tone settings. Make sure that the balance and tone settings are not set to favor the center speaker, and that the left and right speakers are not muted.
  4. Check the receiver's internal audio processing. Make sure that the receiver's internal audio processing is set to play sound through all speakers, and not just the center speaker.
  5. If the above steps don't solve the problem, it could indicate a more serious issue with the receiver's internal audio processing or speaker configuration settings. It's recommended to contact Kenwood customer service or a professional technician for further assistance.
It's important to follow the manufacturer's instructions and guidelines when performing any maintenance or repairs on the receiver, to ensure the safety and proper functioning of the receiver. It's also important to check the receiver's warranty status and the manufacturer's instructions to ensure that the repair or replacement will not void the warranty. Keep in mind that troubleshooting and repairing electronic equipment can be dangerous if you are not familiar with the proper procedures. If you are not comfortable with performing the troubleshooting yourself, it's best to contact a professional technician for assistance.
1/20/2023 9:52:26 PM • Kenwood Audio... • Answered on Jan 20, 2023
I have a Kenwood KR-V7070 and can not get my sub to play. It is hooked up correctly, I just don't know if I have to turn on the sub option on the receiver?
Most likely you will do. Many surround systems have set up procedures redo that if you haven't already tried it.
12/18/2022 12:42:06 AM • Kenwood Audio... • Answered on Dec 18, 2022
Kenwood VR-205 Receiver Logo
Popular Tags
18 questions posted
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Morne Olivier
Steve Nordquist
Steve Nordquist
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Audio Players & Recorders
Most Popular Question
vr 205 shuts off right after turn
  • Audio Players & Recorders
