20 Most Recent Sony HVR-HD1000 High Definition Mini DV, DV Camcorder Questions & Answers
First and foremost shut down the device. Remove the battery if possible for 1 minute. Then restart/power up device. If still no luck or response. Go into the setting and look for the reset to default setting if there is no option for touch screen controls. Best of luck
Sony HVR Video... | Answered on Apr 20, 2014
open it, clean the dust with air blower, check whether either the capstan motor or drum drive motor is struck, try to loosen it with a plastic lever.
Sony Video... | Answered on Feb 29, 2020
this camcorder is an earlier model thus the zoom control motor could be weak, if so open it and take out the camera section and unscrew the zoom control motor, loosen it, some sort of sticky grease on the worm gear also obstructs, clean it with small brush or cotton bud. then apply a little silicon grease. don't let dust go in.
take it to a repair man. some doors open via a small motor with a rubber belt. these belts tend to break due ware and tear.
Sony Video... | Answered on Jan 11, 2020
Hi there.
Try DVD Santa, get it here >>>>>>
http://www.freedownloadscenter.com/Multimedia_and_Graphics/Video_and_Animation_Tools/dvdSanta.html
Please read the instructions before use
Good luck and thanks for using FixYa!!
Sony Video... | Answered on Dec 05, 2019
You won't be able to do it with just a USB cable You will need an analog-to-digital video converter which will take the analog video signal from the Camcorder, and translate it to a digital signal for the computer via the USB interface.
Startech, Dazzle and Roxio are three brands
https://www.startech.com/AV/Converters/Video/S-Video-Composite-to-USB-Video-Capture-Cable-TWAIN-Mac-Support~SVID2USB23
https://www.sony.ca/en/electronics/support/camcorders-tape-camcorders/dcr-trv103/articles/S1F0064
Your iLink port is a Firewire interface, so if you have an older Macintosh computer with firewire, you may be able to go from the camera directly to the Mac with the appropriate 4 pin to 6 pin or 4 pin to 9 pin Firewire cable
Sony Video... | Answered on Nov 04, 2019
Thanks for letting us know. Since you have not, in fact, asked a question, we are unable to supply an answer.
Sony Video... | Answered on Oct 29, 2019
That is probably caused by the mechanism control not being able to determine which mode the deck is in. A new mode switch may cure it but I won't hold my breath as it probably needs a capacitor kit as well.
Sony Video... | Answered on Oct 27, 2019
Nothing wrong with the Canon, but you cannot expect one piece of equipment to play tapes recorded a dozen years ago on equipment of a different make.
Your best bet will be to find someone to transfer the tapes to DVD for you.
Sony Video... | Answered on Oct 16, 2019
This information, and much else that is useful, can be found in the 'manual'.
Sony Video... | Answered on Oct 03, 2019
Sony HVR-HD1000 High Definition Mini DV, DV Camcorder Logo
2 questions posted
Top Sony Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Larry Stiles
Larry Stiles
Al Rush
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
HVR Sony
  • HVR Sony
Most Popular Question
download free drivers camera
  • Video Cameras
