20 Most Recent NordicTrack Treadmill Questions & Answers
try pushing upon the deck to relieve the pressure on the latch. then pull the knob
NordicTrack... | Answered on Nov 28, 2014
go to www.ifit.con directly
sincerely.
ernesto cuadra
managua,nicaragua c.a.
NordicTrack... | Answered on Oct 09, 2014
I think you may need to put it in fold mode first...it may be in incline mode.
NordicTrack... | Answered on Jan 04, 2014
1) replace the batteries by new one with alkalines type and using the same polarities DO NOT use another mark example sony vs everyready. Clean the contacts batteries.
2) Adjust the REED swtich, clean it, tight the connector very well, see the diagram and proceed.
God bless you
NordicTrack... | Answered on Nov 12, 2012
1) adjust the REED switch, see the diagram clean it, tight the connector wires.
2) Lube the deck belt very well. VERY IMPORTANT
3) Lube the rollers bearing too,
4) Test the input voltage motor, if there are the Motor need repair
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
NordicTrack... | Answered on Sep 04, 2012
1) test the outlet wall, put some desk lamp, and see if turn ON the light, is does the circuit is o.k if NOT the circuite is missing , Reset The c.breaker from your house or replace the blown fuse.
2) if everything is o.k, turn ON the treadmill, if does work test the fuse blown y/o reset the c.breaker see the block diagram +diagram
3) test the main switch for loose wires, or bad contacts, or faulty swithc.
4) see any wires loose, maybe broken, or break, tight very well, see if some animal byte some wires connector. repair and TURN ON again.
5) adjust the REED switch, see the diagram clean it, tight the wires connector well.
Try again. God bless lyou
NordicTrack... | Answered on Jul 30, 2012
I just had the same problem. Of course tech support is closed so I sent an email. We'll see if they get it fixed tomorrow.
NordicTrack... | Answered on Mar 26, 2012
1) if your display use batteries ,replace by new ones.2)tight the flexible cord from keypanel vs display board3)tight the display board vs lower board( main motor board)4)see if your have 5VDC to display board coming from lower board.5) Test the lower board is coming the power 115 VCA + 5vdc COMING from power supply (transformer+ diodes+capacitor).6) Display board is faulty or Main Board(Lower board). Of course after you did check the step before. See the block diagram that I did for your illustration.12_14_2011_4_23_02_pm.gifSincerely. Good luck, G-d bless you.
ERNESTO CUADRAMANAGUA,NICARAGUA. C.A
NordicTrack... | Answered on Dec 14, 2011
1) YOU HAVE A COMBO PROBLEM: MECHANICAL+ ELECTRICAL*ELECTRONICS
2) ROLLER BEARING DEFECTIVE3)BEARING MOTOR DEFECTIVE.
Electrical:a)main motorb) TRANSFORMERC) COILD) capacitor faulty
electronic:a) main motor controller faulty.
see the block diagram and test according , the main motor board has aprox 90% of functions of any treadmill. Sincerely. Good luck, and G-d bless you.
1) I am assuming that the breaker is the treadmill and Not from your house.
2)you must test the Main Motor. measure the voltage without load
3)now you must test the main motor controller board.
4) transformer.test .see the block diagram and see how the main motor board has aprox 90% of functions of any treadmill.
12_14_2011_4_11_07_pm.gifGood luck. Sincerely. G-d bless you
ERNESTO CUADRAMANAGUA, NICARAGUA C.A
go to www.ifit.com to the section support, and see the best description for you adjustment or troubleshooting for your display.
Will be a good idea, to tigh the flexible cord for loosing cable,a dn try to proof.
Otherwise will be go Ifitt.
Good luck, G-d bless you, sincerely
ERNESTO CUADRA
MANAGUA, NICARAGUA
NordicTrack... | Answered on Dec 12, 2011
How To Repair a NordicTrack Elliptical
  1. Pulse Sensor. Peel off the plastic. ...
  2. Console. Charge the battery pack by pedaling the elliptical for several minutes. ...
  3. Pedals Squeak and Stick. Loosen screws on the side shield using the Phillips-head screwdriver. ...
  4. Tightening and Loosening the Drive Belt
https://www.livestrong.com/article/159137-how-to-repair-a-nordictrack-elliptical/
https://www.youtube.com/watch?v=s779SR-kCko
NordicTrack... | Answered on Apr 18, 2020
that's good, you know its working
NordicTrack... | Answered on Mar 28, 2020
Last page of free online manual has telephone number to contact for assistance. (I am not posted the phone number on this answer but it is in the manua, because so many fraudulent1 spammers post phone numbers here on FIXYA to deceive callers.)
https://www.sportsmith.net/images/product_support%5CNordicTrack%5C285092%20-%20NORDICTRACK%20CX1055%20ELLIPTICAL%5CNEL9095.2-221998.pdf
NordicTrack... | Answered on Feb 26, 2020
NordicTrack Treadmill Logo
17 questions posted
Top NordicTrack Exercise & Fitness Experts
NOEL
NOEL
Marvin
Marvin
john h
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • NordicTrack Exercise & Fitness
Most Popular Question
785pi
  • Exercise & Fitness
