20 Most Recent
NAD C340 Integrated Amplifier Questions & Answers
Cracking noise nad c340
Sometimes you can find the faulty part by touching the parts inside the amp. Only touch the plastic parts not any metal parts! As it is on one channel you have a good channel to compare the bad. Often small transitors can become noisy so start with them!
11/20/2012 4:55:54 PM •
NAD C340...
Answered
on Nov 20, 2012
What is the maximum speaker wattage for a NAD c340
The specs say 2x50W into 8 ohms. I could not located the 4 ohm specs, but it is logical to assume that you can run 2x100W into 4 ohms.
The back panel seems to imply that 4 ohms is a limit for speakers.
So any speaker over 100W capability should be fine, either 4 ohms or 8 ohms.
10/31/2009 12:25:24 AM •
NAD C340...
Answered
on Oct 31, 2009
Need a transistor spare part for NAD C340
Odd a transistor would have such a #. No 2Fanything series. It is most likely a 2SA949.... a PNP audio driver transistor.
It can be replaced by a NTE-383 (ECG383) transistor, though it's best to order the original # from a Japanese semiconductor supplier like MCM in Ohio.
It's best brought to a good hi-fi or guitar amp repir shop for a proper go-thru & repair.
Mark S. CET Sr. Dover, NH
11/7/2008 3:56:17 AM •
NAD C340...
Answered
on Nov 07, 2008
NAD C340 has lost ability to switch between inputs
I have the same problem which started about a month ago and seems to be getting worse.
I also noticed today, that 1 channel is significantly louder than the other - fault in the pre-amp stage, as feeding the power stage directly gives balanced, albeit extremely loud sound!
Looking on eBay, I found someone else selling an amp with both problems. It would nice to think that NAD would acknowledge a design flaw, and fix for free, but my amp is 5 year old.
11/27/2007 12:00:53 PM •
NAD C340...
Answered
on Nov 27, 2007
NAD S200 one channel is not working
You have a fault in the power amp. Identify the faulty channel by following the input leads. As, a stereo amp is basically two mono amps put together. You can compare the bad channel with the good one. First thing to do is a visual look around. If you see something odd looking in one channel and it's the faulty one, compared with the good channel, you might have found the cause. Look at the devices or device on the heatsink especially. If nothing stands out, the next thing to do is test the channels. You can do this in two ways. First, by touching the parts on each channel (with power on) with an insulated screwdriver. If you get a buzz in one channel and nothing in the bad one, in the same places of course! You might have located the faulty device. You can do the same with a volt meter. The readings should be the same in each channel. Work forward from the end of the preamp stage. Don't bother with the power supply parts, as they are common to both channels. By the way, don't short anything!
2/25/2024 7:26:01 PM •
NAD Audio...
Answered
on Feb 25, 2024
Nad 326bee popping sound?
Does it occur on both channels at the same time, (power supply) or independant channels, (coupling capacitor).
2/18/2022 5:59:47 AM •
NAD Audio...
Answered
on Feb 18, 2022
