20 Most Recent NAD T761 Receiver Questions & Answers
manual
T761 Receiver Manual
NAD T761 ReceiverUploaded on Oct 20, 2013
NAD AV-716 Surround sound reciever, i need any info about it.
Dear sir,i would like to inform you that I mail you a letter by post and you will received it within two weeks time.Regarding NAD AV- 716 details and spare part requirement and also i would like to remind you that my second letter stated all requirements etc.dated 8th march 2013. Please refer to the given below Email address.( [email protected]) Thanking you Your's Sincerely, (T.C.A PEIRIS)
3/9/2013 8:15:13 AM • NAD T761... • Answered on Mar 09, 2013
0answers
0answers
Reset nad T741
Be the first to answer 11/24/2012 5:08:58 AM • NAD T761... • Posted on Nov 24, 2012Be the first to answer
0answers
2answers
The left speaker channel on my NAD T761 receiver
Try to swap the input connector, Hook up the right to left input and then the left to right input. If the symptoms is still there then you have a faulty output IC on the left channel. This is not DIY and I've advice you to send it to repair shop to isolate the problem. Hope that you have only a dry joints on that area.
Thanks for using fixya.
6/28/2012 6:43:18 PM • NAD T761... • Answered on Jun 28, 2012
How can I reset my NAD T747 to factory defaults?
Restoring your T 747 to its factory defaults: At FM mode, press and hold front panel’s LISTENING MODE button until the VFD shows “Factory Reset”.
Cheers!
12/29/2011 3:00:35 PM • NAD T761... • Answered on Dec 29, 2011
Who can repair my NAD T761 in the Newcastle upon Tyne area
HelloGet into this link and find the authorised service center for Nad at your area. www.yell.com/.../video+player+repairs-newcastle+u... - United Kingdom
11/20/2011 5:40:23 PM • NAD T761... • Answered on Nov 20, 2011
Hi I have a NAD
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
5/11/2011 12:22:40 PM • NAD T761... • Answered on May 11, 2011
Hi i cant get any sound out of the unit from the
TURN THE VOLUME DOWN TO A NORMAL SETTING.
Check that speakers are turned ON and then look for inadvertent selection of Mute or Tape Monitor.
I doubt any cables jumped off spontaneously from you playing with settings.
Just the same, go through all of the setup instructions before we assume a hardware problem.
http://www.retrevo.com/support/NAD-T761-Receivers-manual/id/8043bh644/t/2/
or...
If the unit appears to be malfunctioning due to power or internal issues...
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech. Check tyhe
1/26/2011 6:32:13 PM • NAD T761... • Answered on Jan 26, 2011
0answers
How can I reset my
Be the first to answer 11/22/2010 9:21:10 PM • NAD T761... • Posted on Nov 22, 2010Be the first to answer
2answers
Loud humming on my tv and dvr with ny nad 761
The problem is the capacitor on the DSP board C107 2200mf / 16 Volts. Try replacing it and it should be fine
8/10/2010 7:44:27 PM • NAD T761... • Answered on Aug 10, 2010
NAD S200 one channel is not working
You have a fault in the power amp. Identify the faulty channel by following the input leads. As, a stereo amp is basically two mono amps put together. You can compare the bad channel with the good one. First thing to do is a visual look around. If you see something odd looking in one channel and it's the faulty one, compared with the good channel, you might have found the cause. Look at the devices or device on the heatsink especially. If nothing stands out, the next thing to do is test the channels. You can do this in two ways. First, by touching the parts on each channel (with power on) with an insulated screwdriver. If you get a buzz in one channel and nothing in the bad one, in the same places of course! You might have located the faulty device. You can do the same with a volt meter. The readings should be the same in each channel. Work forward from the end of the preamp stage. Don't bother with the power supply parts, as they are common to both channels. By the way, don't short anything!
2/25/2024 7:26:01 PM • NAD Audio... • Answered on Feb 25, 2024
I have a Nad Receiver T748 , I can not connect any device with HDMI at port 2, 3, 4, only port HDMI 1 is working.What should I do
I have nad t748 but not switching on the power on tha auto turn off
7/23/2023 4:01:40 AM • NAD Audio... • Answered on Jul 23, 2023
I have a NAD 1600 receiver for 40 years. It always worked fine!! I just moved it 15 feet to new room and volume seems stuck on high! Knob turns but volume doesn't change. What happened??
It is funny, I was just reading an article today about New Acoustic Dimension Cassette decks saying they were top of the line and equal to Nakamichi. The most likely reason is that the volume control needs cleaning with Electrical Switch Cleaner. You would have to remove the case and look. It is worth a quick spray. This says it has a motorized volume control. https://www.google.com/search?q=nad+1600+receiver+volume+on+high+volume ..
2/24/2023 3:31:57 AM • NAD Audio... • Answered on Feb 24, 2023
NAD T761 Receiver Logo
17 questions posted
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • NAD Audio Players & Recorders
Most Popular Question
get any sound out unit from
  • Audio Players & Recorders
