20 Most Recent Celestron NexStar 114GT (269 x 114mm) Telescope Questions & Answers
When I look through the view finder--everything is upside down???
Astro telescopes normally do show an inverted image, since for most purposes this does not matter. For terrestrial viewing, such as thru someone's window, you can buy an "erect image" or "correct image" prism which gives an upright image. http://www.optcorp.com/telescope-accessories/optical-tube-accessories/diagonal-prism-eyepiece-holder.html?a_diagonal_design_f=1090 I don't know of such a thing for the finder scope, you would have to buy a new finder. http://www.optcorp.com/celestron-9x50-illum-ra-correct-image-finderscope-93781.html
4/10/2014 12:48:48 PM • Celestron... • Answered on Apr 10, 2014
What are the lense cap diameters?
Eyepieces come in two popular sizes 1.25 in. and 2". Some older 'scopes have 0.96 inch eyepieces.
3/2/2014 9:51:40 AM • Celestron... • Answered on Mar 02, 2014
Focus knob on Celestron NexStar 5 does not appear
Does the focuser move in and out when you turn the knob? If it does then go outside during the day timne and practice focusing on a distant object. Use the eyepiece with the biggest number written on it.
This will give you the lowest magnification-- which is easier to focus.
6/16/2011 5:47:40 AM • Celestron... • Answered on Jun 16, 2011
How do i conect my
You need to buy a USB-to Serial adapter cable like this one:
http://scopestuff.com/ss_usbr.htm
scopestuff.com sells these. The Keyspan brand USB-Serial adapter is also a good one.
5/28/2011 5:50:26 PM • Celestron... • Answered on May 28, 2011
I have celestron brand 114mm
Usually the lens cap just pops off -- the bottom where the mirror is located should not be removed.
These scopes do NOT have screw on lens caps. ?
5/9/2011 8:13:52 PM • Celestron... • Answered on May 09, 2011
If you have a product
And what is your question?
5/9/2011 8:12:39 PM • Celestron... • Answered on May 09, 2011
The motor controller of by
Only Celestron will have that part. Contact them here:
http://www.celestron.com/c3/page.php?PageID=37
2/25/2011 2:35:00 PM • Celestron... • Answered on Feb 25, 2011
I have a celestron nex star 114gt and the tripod
You can try and contact Celestron directly-- and or a Celestron dealer. Here are two links:
http://www.celestron.com/c3/page.php?PageID=37 Celestron
http://www.optcorp.com/ a Celestron dealer
10/23/2010 4:01:31 PM • Celestron... • Answered on Oct 23, 2010
Motor for elevation does not run. The traverse
This old scope may not be worth repairing-- contact Celestron directly here:
10/2/2010 6:10:06 PM • Celestron... • Answered on Oct 02, 2010
I just bought a used
Can you see something in the distance during the daytime?
Did you do the training, set the TIME
Did you do a two star alignment?
You must follow the setup procedure exactly for the scope to have accurate gotos.
Get the manual out and read it several times. You can practice inside just to get familiar with how the scope operates.
9/7/2010 7:38:37 PM • Celestron... • Answered on Sep 07, 2010
When viewing venus or other stars there a black
You are NOT in focus. Turn the focus knob a little until you see a perfect "disk" for the planet. Stars are always POINTS of light, with a telescope or without a telescope.
8/28/2010 11:22:46 PM • Celestron... • Answered on Aug 28, 2010
Hi, Bought a used telescope with a GT mount. The
This scope does NOT need to be polar aligned --
Here is the manual:
http://www.celestron.com/c3/images/files/downloads/1228334587_nexstargt.pdf
This is an ALT AZ goto scope. Read the manual above. You use the hand controller to move the scope in Altitude and Azimuth(left-right).
You must align it on 2 stars in order for it to has successful gotos.
8/22/2010 12:56:40 AM • Celestron... • Answered on Aug 22, 2010
Why is the cap at the end smaller thna the
Yes, that's the point of it.
Remove the entire (full diameter) cap for stellar and planetary viewing, or just the smaller diameter central cap for viewing the Moon which is far brighter and is too bright without either adding a neutral density filter or by partially masking the optical tube assembly.
2/24/2010 10:37:54 PM • Celestron... • Answered on Feb 24, 2010
Azimuth Drive failure on Nexstar 114
Hi Dan, before you ship it off somewhere, you may want to try and change out the hand controller with another one that someone has and see if the problem moves.
11/5/2009 8:20:58 PM • Celestron... • Answered on Nov 05, 2009
How long does the back up take?
I don't know what a Celestron would take, but as a point of refrence, the Meade telescopes typically take 1 hour.
8/30/2009 6:03:15 AM • Celestron... • Answered on Aug 30, 2009
I need the power plug (female part) that is on the
Call any Celestron dealer.
Here is one Celestron dealer-
7/5/2009 1:37:29 AM • Celestron... • Answered on Jul 05, 2009
Nexstar 114gt i have no instruction manual
You can find the manual in pdf form here:
http://www.celestron.com/c3/downloads.php?Products[]=528&Submit=Search
4/9/2009 8:20:37 PM • Celestron... • Answered on Apr 09, 2009
Celestron NexStar 114GT (269 x 114mm) Telescope Logo
22 questions posted
Top Celestron Optics Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Celestron Optic Expert? Answer questions, earn points and help others
View Most Popular
Celestron Optics
  • Celestron Optics
Most Popular Question
when viewing venus or other stars black
  • Optics
