20 Most Recent Swingline 48209 Optima ® 45 Electric Stapler Questions & Answers
The top and bottom pieces are held in place by plastic press fit clips near the corners. These can be carefully pried off to expose the four screws that holds the two main halves of the main body together. Two along the top and two along the bottom edges. remove-cover-swingline-48209-tnvqfkqwrdbsi2jhlz5a3kts-5-0.jpg
Swingline 48209... | Answered on Jun 13, 2020
All you need is to use a thin sharp wire rod to push the damaged/cramped pin out of the hammer. You can achieve this only if you can have such a tool , remove the lid to get access, manually turn aside to relieve the presssure on the damaged pin, remove the cartidge and replace after the pin is removed. You can also slightly tap to get the pin released from the jammed position.
Swingline 48209... | Answered on May 22, 2014
Swingline 48209 Optima ® 45 Electric Stapler Logo
99 questions posted
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Arnie Burke
Arnie Burke
Kenneth Walker
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Swingline Office Equipment & Supplies
Most Popular Question
remove cover swingline 48209
  • Office Equipment & Supplies
