The 0015.111 error is caused because you installed using a wrong Product Key (example 781E1 instead of 495E1), where both codes will work but if not used the correct one it will originate a 0015.111 when trying to activate. You will need to reinstall and insert the correct Product Key.You can see all the correct Product Keys for all 2010 to 2014 products at http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19726927&linkID=12305695
The 0015.111 error is caused because was used a wrong Product Key (example 781E1 instead of 495E1), where both codes will work but if not the correct one it will originate a 0015.111 when trying to activate. You will need to reinstall and insert the correct Product Key.You can see all the correct Product Keys for all 2010 to 2014 products at http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19726927&linkID=12305695
