20 Most Recent Powr Flite PFX1380 Steam Cleaner Questions & Answers
Hi from what i have read about your steam cleaner thr filter should just lift out, failing this, give it a bit of a wiggle to help release it
hope this helps
Powr Flite... • Answered on Mar 03, 2011
Can you get to the pump and turn the shaft? 9 out of 10 times the reason that the belt broke was that the pump froze up from residue and rust.
Vacuums • Answered on Apr 28, 2021
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=759260
Generic problem for all Vacuums
Download instruction manual?
Posted by mvassian on Jul 09, 2008
For the Kenmore 3 in 1 deep cleaner model 20 86603--is that possible? Thanks, Myra
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best place to get this type of information is either the Sears / Kenmore website or to cal the Sears / Kenmore factory to have then either download the information or to send out or mail out the information by US Mail. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Rubbermaid! I hope Hygiene for All is a double act, spam tag team?
Vacuums • Answered on Apr 26, 2021
Makes no difference. Purchasers decorate how they want.
Yeah, I also have the same problem. I don't know how to fix it, Man
Vacuums • Answered on Apr 21, 2021
I think it is this robot vacuum cleaner: Bagotte BG800 Robot Vacuum Cleaner I am a cleaning enthusiast. I have used many brands of robot vacuum cleaners, but I found that their cleaning effect is almost the same. I suggest that you can choose a robot vacuum cleaner that is cost-effective in the market as your household cleaning tool. Besides, I have a Poodle. She is very lively, always bouncing on my sofa or bed. So my sofa and bed are full of her hair. Animal hair itself tests the suction and cleaning ability of the robot vacuum cleaner more than other garbage and dust, but Bagotte BG800 Robot Vacuum Cleaner does it. At last, maybe this blog can help you: https://bagottelife.com/blogs/tips/what-is-the-best-robot-vacuum-cleaner-for-pet-hair
Some of the Dirt Devils have a reset button on the back, near the bottom. But if the it is getting hot on the bottom, that may mean the motor is trying to run but can't. Maybe something has jammed it. You would have to disasemble it to find out.
Vacuums • Answered on Apr 18, 2021
measure the size and hit home depot
Vacuums • Answered on Mar 27, 2021
https://www.weeklytools.com/category/vacuum-cleaner/ With the growth of technology, vacuum cleaners' importance to keep your beloved home clean is endless. A machine can be disabled. But there is a solution. Following a few simple steps will help you to repair a damaged vacuum cleaner at home. So, Let's discuss Vacuum Cleaner Repair. If your vacuum can't work like before
Vacuums • Answered on Mar 13, 2021
I had the same problem. Red light would come on after charging was complete. On investigation I found that there is a small gray wire that runs from the rear batteries to a large solder spot on the control board. Upon re-soldering this wire I got an additional 3 V of power and the red light does not come on anymore after it is charged. I can vacuum the whole house and then some and still not run the batteries down.
Vacuums • Answered on Mar 10, 2021
make sure nothing has stuck under it or try and remove the battery for 30 mins and replace. If that doesnt work, there could be a fault in the electronics
Vacuums • Answered on Mar 09, 2021
What brand, upright/canister, does the motor run, is there any air flow at the hose?? Without more information it is a best guess that the airflow pathway (hose and/or ducting) is blocked with debris. Also, a filter might be dirty or blocked, the motor fan could be broken or plugged with debris (less likely) or the exhaust duct could be restricted/blocked. Details matter.
Vacuums • Answered on Mar 06, 2021
Pull it out, or turn that nut anti-clockwise with a socket wrench / spanner, replace the cable.
Vacuums • Answered on Mar 04, 2021
Powr Flite PFX1380 Steam Cleaner Logo
1 questions posted
Top Powr Flite Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Powr Flite Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Powr Flite Vacuums
  • Powr Flite Vacuums
Most Popular Question
remove filter in waste tank
  • Vacuums
