20 Most Recent
Energy Speakers ESW V10 Subwoofer Questions & Answers
How to set alarm Ikea Slabang clock
1. Press and hold the "+" or "-" button to enter the alarm settings.
2. Press the "+" or "-" button to choose the desired hour for the alarm.
3. Press the SET/RESET button to confirm and move to the minutes setting.
4. Press the "+" or "-" button to choose the desired minutes for the alarm.
5. Press the SET/RESET button to confirm and move to the alarm mode setting.
6. Press the "+" or "-" button to choose the desired alarm mode (i.e. one time, daily, or weekdays).
7. Press the SET/RESET button to confirm and activate the alarm. The ALARM indicator light will turn on when the alarm is active.
8. To turn off the alarm, press the SET/RESET button. The ALARM indicator light will turn off when the alarm is deactivated.
How can I turn off shuffle mode in my playlist on alexa?
You can turn off shuffle mode in your playlist on Alexa using the following steps:
- Open the Alexa app on your mobile device.
- Tap on the "More" tab at the bottom of the screen.
- Select "Music & Books" from the list.
- Tap on "Amazon Music" or the music service that you are using.
- Tap on "Playlists" and select the playlist you want to play.
- Tap on the play button to start the playlist.
- While the playlist is playing, tap on the bar at the bottom of the screen to expand the player.
- Tap on the "Shuffle" button to turn it off.
Alternatively, you can say "Alexa, turn off shuffle" while the playlist is playing to turn off the shuffle mode.
Off button doesn't work on lifestyle 5 music centre
You may need to check the power source, power cord, or power outlet first. If those are working fine, then you may need to contact Bose support or a repair technician to diagnose and fix the issue with the off button.
