20 Most Recent Lenovo G530 4446-38U (890552663385) PC Notebook Questions & Answers
Uninstalled two intel programs by mistake. Now can't figure out how to get them back (did not save settings). Lenovo test indicates that the local video memory is not supported. How can I fix this
You need to go to Lenovo website and look for the latest drivers according to your model and OS
12/20/2012 5:59:08 PM • Lenovo G530... • Answered on Dec 20, 2012
3answers
How do you title a photo on Lenovo tab7?
Hello, also you can be creating a file, albun, if you do not find the option in the Tab7 you can download one from the Google Play. Photo Editor Pro Apps on Google Play
8/23/2021 8:29:53 AM • Lenovo Computers... • Answered on Aug 23, 2021
I want to use my mouse pad (FISSION) with usb hub with my LENOVO X130e computer-what is the procudure?
This is more a question of if it needs specific drivers for the fission and which version of windows you are running. Have you plugged it in and see if it's recognized by usb?
8/13/2021 11:13:20 AM • Lenovo Computers... • Answered on Aug 13, 2021
Lenovo G550 and DDR3 memory 8GB
hi certainly you replace the display with a new 1 buy a new 1 and install it by yourself or go to your service provider have a good 1 https://optap.in
7/28/2021 2:34:43 PM • Lenovo Computers... • Answered on Jul 28, 2021
Will MSR606 software work for my labtop i have lenovo qualcomm with windows 10
The MSR606 is a magnetic strip Card Reader so, I would expect the software to work with you laptop. However, you should check the specifications of the software to ensure it is compatible with the amount of RAM, HDD free space and Processor. Software is easy to uninstall, so, try it. Do you have the port you will need to connect your reader. (Parallel, serial, USB, Firewire, etc.)
7/27/2021 2:41:55 PM • Lenovo Computers... • Answered on Jul 27, 2021
Lenovo ThinkPad Edge E540 type 2OC6 very slow
It may be because it is full of unused and unwanted files and parts of files. Try cleaning out the system. Plenty of hdd cleaners available on the net.
7/27/2021 1:44:05 PM • Lenovo Computers... • Answered on Jul 27, 2021
2answers
How do I download Lenovo manual for Lenovo Tab M10 HD
Try the lenovo web site. https://pcsupport.lenovo.com/gb/en/products/tablets/m-series-tablets/tab-m10-hd/documentation/doc_userguide
4/10/2021 11:46:04 AM • Lenovo Computers... • Answered on Apr 10, 2021
CALIBRATE THE COLOUR TEMPERATURE IN MY LENOVO LAPTOP
https://forums.lenovo.com/t5/ThinkPad-Edge/Can-I-change-the-color-temperature/td-p/674445 https://forums.lenovo.com/t5/ThinkPad-P-and-W-Series-Mobile/Can-you-change-color-white-temperature-of-the-display/td-p/4204703
Lenovo Community - Lenovo Forums
forums.lenovo.com > topic > findpost
Sep. 15, 2015 - Re: Lenovo Y70 How to Change the Screen Color Temperature. 2015-09-15, 20:27 PM. Hi, I followed your instruction and the screen colors are ...
Apr. 13, 2015 - I tryed to adjust the color calibration through the interal display functions ... that you facing issue with display calibration in your Lenovo G50-45 laptop. ... Particularly the much too high color temperature that is seen in a visible ...
2/22/2021 6:32:58 PM • Lenovo Computers... • Answered on Feb 22, 2021
My lenovo m500 gives a mirror screen on my desktop pc
The only reason is that you just enabled display mirroring on another PC. You can disable it by following the steps below. 1.Open your Display settings via the Control Panel or by right-clicking the desktop and choosing Screen Resolution. 2.In the Multiple Displays dropdown, select Extend desktop to this display.
1/28/2021 8:37:51 AM • Lenovo Computers... • Answered on Jan 28, 2021
Lenovo CIH61MI V1.1 motherboard,how to connect the front panels(new case)
you will have to short and see. mostly the 2 pins (horizontally) near the single pin is the power button or reset or vice versa.
1/18/2021 9:37:01 PM • Lenovo Computers... • Answered on Jan 18, 2021
How can i fix my lenovo laptop with a black screen when turned on
test with an external monitor. if you see video, then your laptop screen is bad. if you don't see video, then your video card or motherboard is bad.
12/6/2020 3:08:48 PM • Lenovo Computers... • Answered on Dec 06, 2020
I have a Lenovo ThinkPad that cannot be turned ON. Assuming the battery is faulty but I want to turn it ON using the adapter
What is the model of the Thinkpad? There should be a reset hole on the bottom of the computer. Unplug the computer, remove the battery if possible, turn the computer over and gently insert a paperclip into that tiny hole. You will feel a click, hold it there for about 15 seconds. Remove the paperclip, turn over and hold down power for 15 seconds, then release. Put in the battery, plug in and press power.
12/6/2020 2:05:04 AM • Lenovo Computers... • Answered on Dec 06, 2020
2answers
My laptop lenovo G560 internal speaker not working how to rectify
reinstall the audio drivers again some windows updates cause this problem
10/29/2020 10:05:08 AM • Lenovo Computers... • Answered on Oct 29, 2020
How do I unlock my Lenovo ideapad laptop model 110
Good Day Is it bios password or windows password?
10/21/2020 11:37:34 AM • Lenovo Computers... • Answered on Oct 21, 2020
How to type hash key in lenovo laptop
You will have to use the shift and the corresponding hash key!
5/10/2020 9:34:02 AM • Lenovo Computers... • Answered on May 10, 2020
2answers
Laptop wont play dvd
need to try cleaning it if that dont work replace it they are inexpensive
4/24/2020 1:37:47 PM • Lenovo Computers... • Answered on Apr 24, 2020
How to fix slot has been permanently lock lenovo s90-a
how to remove sim slot permanently lock in lenovo s90-a
3/12/2020 10:20:37 AM • Lenovo Computers... • Answered on Mar 12, 2020
Ac adapter for lenovo thinkpad is lose,connects only at a certain angel,adapter #65w 20v.Is there quick fix or do i need to buy a new adapter
If the plug is the problem then you can replace just the faulty end. Many times actual socket in laptop it the problem and may not to be easy to repair
2/15/2020 3:02:56 AM • Lenovo Computers... • Answered on Feb 15, 2020
Lenovo G530 4446-38U (890552663385) PC Notebook Logo
1 questions posted
Top Lenovo Computers & Internet Experts
Ekse
Abhinandan  Patil
Abhinandan Patil
Steve Sweetleaf
Steve Sweetleaf
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lenovo Computers & Internet
Most Popular Question
uninstalled two intel programs mistake
  • Computers & Internet
