20 Most Recent True TD-95-38-LT Beverage Cooler Questions & Answers
If it is a number thermostat, first check your box temp., then change the dial 1 number and check temp. in about 2-3 hours and see which direction it goes. Usually thermostats with numbers causes the temp to change very slowly so take your time and you can figure it out.
True TD-95-38-LT... | Answered on Jan 16, 2018
First, dont overstock your beer, good circulation is key. Make sure your condenser coils are clean. Find a happy setting with the help of a thermometer to cool between 35 - 42 degrees. To defrost I put big zipl-loc bags of ice on top of beer. Turn temperature all the way up (the compressor will cut off but the fan will keep running) for a few hours. When the ice is thick i put HOT water in a squirt bottle and spray sections in the ice. Play around with that and see if it works. Hopefully you don't have a bad condenser. Good luck!
True TD-95-38-LT... | Answered on Mar 01, 2015
Usually inside the compressor compartment, below that is the collection pan, blow it out with compressed air
True TD-95-38-LT... | Answered on Oct 29, 2013
I go to Home Depot to get their aluminum 'L' bracket (3 ft or 4 ft lengths, etc by 3/8th or 1/2 inch), usually by their screw and nail aisle. Depending on whether the rail you're fixing is on the box's outside frame edge or an separating inner edge, you'll need to turn the 'L' either up or down so that the screws to attach it have something to bite into. I also add a line of Gorilla glue to the aluminum and wet the edge it need to attach to for extra strength.
True TD-95-38-LT... | Answered on Feb 03, 2012
Check your evaporator drain pan and the outlet for the condensate water, and make sure the drain tubing is clear. That water is supposed to drain outside the box.
True TD-95-38-LT... | Answered on Aug 30, 2011
Can you tell me what your problem is though?
True TD-95-38-LT... | Answered on Apr 01, 2011
can u be little more precise in ur questioning ??so that we can solve ur problem
True TD-95-38-LT... | Answered on Mar 31, 2011
True TD-95-38-LT Beverage Cooler Logo
32 questions posted
Top True Refrigerators Experts
Dennis Boxerman
jdthefixer
Muntejaya Ginting
Muntejaya Ginting
Are you a True Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
True Refrigerators
  • True Refrigerators
Most Popular Question
td 95 38 unit drain
  • Refrigerators
