20 Most Recent Panasonic CQ-C7301U CD Player Questions & Answers
the brown/white is probably phone mute. the blue is power antenna remote turn on and the blue/white is amplifier remote turn on.
Panasonic... • Answered on Mar 22, 2011
dice electronics makes a universal adapter dce-fmrds.jpg go to my online store it is under FM Modulators you can buy this item it not cheap
dice i-fm rds and i can ship it to you
http://www.tintingbyfredjohnson.com
Panasonic... • Answered on Dec 22, 2010
have a look if the surrounding black plastic area, will that come off to allow you to see the removal clips ?? Dont force it as you may damage it, but it should just lightly clip off.
Heres a tip for ya................
when ever i fit a new stereo in my car i never fix it in securly, i just slide it in the hole and leave it. Why i hear you ask !!....well if someone is going to break into my car to steal it i dont want them to smash **** out of my dashboard to get it, they have probably already caused damage getting in. If they make the effort getting in my car by force then they can have the stereo with pleasure, just dont destroy my dash aswell.
Panasonic... • Answered on May 17, 2010
i am assuming you are running audio through an amp. if this is the case you are probably using the antenna remote wire (solid blue) instead of the amp turn on wire (blue w/white stripe) to turn the amp on.
Panasonic... • Answered on Apr 14, 2010
Looking at the user manual on page 13, you have to purchase and connect the XMD1000 module to in order to get the satellite radio service. If the module is installed, you'll get a display telling you to sign up for service.
Panasonic... • Answered on Feb 24, 2010
GO TO THE RADIO SHACK THEY HAVE ALL KINDS OF GREAT STUFF LIKE THAT OR GO THE PANASONIC WEB SITE
Panasonic... • Answered on Nov 12, 2009
There isn't one. But the car has fuses and the dome,hazard,radio,orbody fuse couls have blown and caused this problem. While your cheakiing the fuses with a light ( test light) check them all. and the new correctly installed fuse will solve your problem and isolar=te this stray wire so it doesn't short again
Panasonic... • Answered on Nov 02, 2009
You will need to get the XM add-on that Panasonic makes in order to get the functionality I think you are trying to get. With an external radio, you could hook it into an Aux to get sound, but you would not have the options to change channels from the Panasonic. In order to do that, you will have to buy their add-on. I have a separate Sirius Radio, and I prefer it that way because the display is so much easier to read.
Panasonic... • Answered on Oct 09, 2009
Either in the bottom corners on the face or behind the face on the radio itself. Paper clip size hole.
Panasonic... • Answered on Jul 06, 2009
you may have damaged the battery and may need a new 1 and also check the wireing on the dash board as the perminant live which is the yellow wire could be connected to the live which is the red wire on the radio which keeps the radio on even if the keys are out the ignition
Panasonic... • Answered on Jul 05, 2009
Hello ly2004sxt,
You do not need a code to play CD's in a Panasonic CQ-C7301U. The player handles the standard CD format and also plays burned CD's in WMA or MP3 formats. However, burned CD's in WMA format that contain copyrighted music are not playable. In this case the display will show "PROTECTED".
Hope this helps.
Panasonic... • Answered on Jun 02, 2009
You are on the right track. Those "little metal things" come in handy. Ensure you have removed any necessary aftermarket plastic framing. Many times with the new deck kits, we need to insert the plastic framing. Slide the tool on the side of the deck itself, so look carefully and be sure not yank on the deck. Let me know where you are at.
Panasonic... • Answered on May 06, 2009
Ensure that the rf cables are well fitted. You may swap if you are not sure.
rate this
Panasonic... • Answered on Apr 07, 2009
If you have a short anywhere it could have blown the amp. I've seen that happen when one of the speaker wires was exposed and touching ground.
Panasonic... • Answered on Jun 20, 2008
Panasonic CQ-C7301U CD Player Logo
40 questions posted
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Michael Thomas
Michael Thomas
 TE5LA
TE5LA
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Car Audio & Video
Most Popular Question
sirius ready cd player installed in
  • Car Audio & Video
