20 Most Recent Sennheiser CX 680 Sports Headphones Questions & Answers
  • You can get replacement parts here.
  • Please reply if you have any more questions. Good luck! (Please give a thumbs up, I am doing this for a summer job!)
Sennheiser CX... | Answered on Jul 27, 2018
You need to fix disconnected cable on your left earphone
Sennheiser CX... | Answered on Mar 05, 2011
It is likely that from ware and tare that one of the wires has come apart inside the line so it is time to buy a new pair
Sennheiser CX... | Answered on Feb 28, 2011
Hello Timothy, the microphone has a 3.5 mm connector, which has a thread, you must unscrew this thread and you should be able to exit
Discuss the type of connector you have
I hope you can solve the problem
Greetings Franco Dosil
Hola Timothy, el microfono tiene un conector de 3,5 mm, que tiene una rosca , debes desenroscar esta rosca y tendria que poder salir
Comenta el tipo de conector tiene
Espero puedas resolver el problema
Saludos Franco Dosil
https://assets.sennheiser.com/global-downloads/file/8949/SK_100_G3_Manual_12_2016_EN.pdf
Sennheiser Audio... | Answered on Jun 21, 2019
Hi David, comment that cables are wrong in the transmitter, to try to find the best possible solution
I wait your answer
Hola David, comenta que cables estan mal en el transmisor, para tratar de encontrar la mejor solucion posible
Espero tu respuesta
https://www.fullcompass.com/brand/sen-sennheiser/replacement-parts
https://en-us.sennheiser.com/accessories
http://www.hifiheadphones.co.uk/spares-accessories/sennheiser-spares.html?currency=EUR&dir=desc&limit=5&mode=list&order=name
Sennheiser Audio... | Answered on Jun 07, 2019
Hello Mike, your LG TV, does not have a headphone output, it only has optical fiber audio output
the options that I suggest are,
1) Connect the optical fiber output of the LG, to an AV receiver, that has said input and place the headphones in this equipment,
2) Buy an optical fiber to audio converter by RCA L and R and this is connected to a headphone amplifier
I send you links to the products that are sold in my country
I hope you solve your concern
This is the headphone amplifier
This is the optical fiber to audio converter by RCA L and R
Hola Mike, tu TV LG, no cuenta con salida de auriculares, solamente tiene salida de audio por fibra ?ptica
las opciones que te sugiero son,
1) Conectar la salida de fibra ?ptica del LG, a un receptor AV, que cuente con dicha entrada y colocar los auriculares en este equipo,
2) Comprar un conversor de fibra ?ptica a audio por RCA L y R y este conectarlo a un amplificador para auriculares
Te env?o links de los productos que se venden en mi pa?s
Espero logres resolver tu inquietud
este es el amplificador de auriculares
Este es el conversor de fibra ?ptica a audio por RCA L y R
Este es el amplificador de auriculares
https://articulo.mercadolibre.com.ar/MLA-784156450-behringer-ma400-ultra-compact-monitor-auricular-amplificador-_JM
This is the fiber optic to analog audio converter
https://articulo.mercadolibre.com.ar/MLA-707192478-convertidor-audio-digital-toslink-optico-coaxial-a-rca-nuevo-_JM
Sennheiser Audio... | Answered on May 01, 2019
Hi Edgar, it is important that the receiver works, because there is a dialogue between the transmitter and the receiver to confirm that they are on the same frequency, that is why the transmitter is blinking, you should repair the receiver and look for the frequency or channel that the transmitter is found and it will stop flashing
Hola Edgar, es importante que el receptor funcione, porque hay un dialogo entre el transmisor y el receptor para confirmar que est?n en la misma frecuencia, por eso es que el transmisor esta titilando, deber?as reparar el receptor y as? buscar la frecuencia o canal que se encuentra el transmisor y este dejara de titilar
Sennheiser Audio... | Answered on Apr 15, 2019
Sennheiser CX 680 Sports Headphones Logo
10 questions posted
Top Sennheiser Audio Players & Recorders Experts
Marvin
Marvin
Vernon Taylor
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sennheiser Audio Players & Recorders
Most Popular Question
need replacement ear pads pmx 680
  • Audio Players & Recorders
