20 Most Recent
Sony VAIO VGN-NW350F/S Notebook Questions & Answers
Base system device iis missing
goto sony website then support and search ur model no and drivers then select chipset driver on that site download and install
problem sloved
2/6/2014 11:56:42 AM •
Sony VAIO...
Answered
on Feb 06, 2014
Download driver sound
If he dropped it he probably broke the sound device. Reinstalling drivers will do nothing. The only solutions is using headphones but it is likely to not work.
8/20/2013 5:42:48 PM •
Sony VAIO...
Answered
on Aug 20, 2013
After doing a frest windows
You need to install a software for it. Check the CD drivers of your laptop look for launch manager software or similar to that after installation your FN combinations should work. If you dont have the cd drivers go to sony's website look for the support download page and search your particular model. hope that helps
9/5/2011 1:15:43 AM •
Sony VAIO...
Answered
on Sep 05, 2011
My sony vaio vgn nw250f
6 months is about right for the fan to become clogged and need re-cleaning. You could try the basics, which is:
1) Don't operate the laptop on your lap.
2) Ensure the vents are kept clear at all times
3) From time to time, simply blow into the vent holes to dislodge any dust.
4) If you can, use a laptop cooler to keep the temperature down in the laptop.
Sorry, I know overheating laptops are a pain, but it sounds like you are already doing as much as you can to reduce/stop/fix this.
7/31/2011 3:56:15 PM •
Sony VAIO...
Answered
on Jul 31, 2011
My computers green light turns
You LCD went bad, although it could just be a loose ribbon cable inside the laptop. You need to have a technician look at it.
LCD replacements cost around $100 - $200 with parts and labor.
5/8/2011 11:01:06 PM •
Sony VAIO...
Answered
on May 08, 2011
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
