20 Most Recent
True TWT-48 Stainless Steel Commercial Refrigerator Questions & Answers
True Freezer
Hopefully you were good on cap tube length is this is an important aspect of this system.The length must be matched
True TWT-48...
Answered
on Jul 01, 2009
My True TD 50 18 beer cooler does not cool beers
If you hear a clicking noise coming from the compressor there is about a 80% chance that the compressor is dead. But you'll have to call someone out to be sure.
If the fan motor behind the grill is running (condenser fan) then the compressor should be running and vice versa. If the compressor is hot as a pistol and clicking and the fan motor is not working then it may cool down if you shut it off and you might just have a bad fan motor. With power turned off the condenser fan motor should freely spin. Compressor have a 5 year warranty from the manufacture not including labor and additional materials. Hope this helps.
True...
Answered
on Jan 11, 2021
True Freezer, compressor not turning off. It is getting cold. The fan inside turns on and off but compressor runs for hours.
Hello Vic, I'm not sure what model of Freezer you have, but I suspect that the "condenser" coils on the back or underside of the unit need to be vacuumed or cleaned to rid of the dust bunnies, cat/dog hair etc. The compressor is likely trying desperately to do it's job, but that array of pipes are the only way it can get rid of the heat that it is stealing from the inside of the freezer. IF the coils are clean or if it still keeps running after cleaning... no matter what setting the "cold" dial is set to, then likely there could be a relay that has fused close preventing the unit from cycling properly. I hope this helps! /The GreyOne
True...
Answered
on Sep 08, 2019
