20 Most Recent Panasonic CT-32G11 32" TV Questions & Answers
call a technician to look for it. there must be loose components inside
Panasonic... | Answered on Dec 03, 2017
You first need to rplace the outlet if it sparks where the surge protector is plugged in as it should not spark for any reason. then you need to make sure thast its not the outlet causing your problem by running an long extensition corn or moving the set to a differant outlet.
Panasonic... | Answered on May 16, 2013
try putting a small fan behind the set to cool it.
Panasonic... | Answered on Mar 27, 2013
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Panasonic... | Answered on Feb 29, 2012
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Panasonic... | Answered on Jan 03, 2012
Hi.
If the TV is completely dead , then it is usually either power cord, power outlet or PSU. Other faults are quite unlikely to cause no power.
Since you can start TV from remotem then the problem is not a dead TV with no powe.
In your case the TV is in standby and does not wake up.
Try first using the channel up and down in the TV panel (not remote), if they operate the TV, then problem is the remote.
If the TV does not start using channel buttons, then the TV is in forced standby because a fault is detected.
In that case the stand by indicates that an internal fault has been detected. In theory you will need to call the service number listed on the user manual to get a technician to test your TV.
If you can start the TV occasionally, then common faults can concern the button board including IR sensor from TV, PSU, convergence , flyback and more.
Try first leaving the TV disconnected for at least one hour and see if it does start after that.
Also do a test with no connected device. mark connection cables to receiver and optical unit as necessary, then start TV with nothing connected. You should get no signal but TV will start unless faulty.
If it does then it is probably PSU or convergence ICs. Repair will be no less than $150/$200.
The TV can still be repaired, if there is a fault however I suggest to passing to a flat panel TV, which is more efficient and less power consuming than the CRT TV.
Panasonic... | Answered on Sep 30, 2010
POWER TRANSISTOR SHORT CHECK Q735 2SD1266 OR REPLACED
Panasonic... | Answered on Jun 08, 2010
repar is
replace stk 730-020 i have them in stock
replace c809 capasitor value is 22uf at63v not in stock
replace location f801 t4a not instock
[email protected]
thanks
daniel.
Panasonic... | Answered on Nov 02, 2009
you need some caps changed in that set in vertical circuit
i usually change about 5 caps to cure the problem
caps go bad over time
Panasonic... | Answered on Aug 29, 2009
6.3
Panasonic... | Answered on May 20, 2009
My exact same TV did the same thing. Your fuse us going bad. Go buy a new one and replace it.
Panasonic... | Answered on Jan 13, 2009
when mine it, i had to replace a fuse
Panasonic... | Answered on Aug 15, 2008
Only 10 years old??? Ok its most likly at the end of its usefull life, unless you want to put some cash into the set, as there are no user replaceable parts inside this TV, so you really should let a trained tech estimate it for you. But once you fix it, you most likly will start have problem after problem. Do yourself a favor, and buy a new one. The problem with this set is most likly the flyback and other componets or the power supply capacitors are bad.
Panasonic... | Answered on Oct 01, 2006
Probably power supply failure
Panasonic... | Answered on Nov 11, 2020
The MENU button might be only on the remote control.
Panasonic... | Answered on Nov 10, 2020
Televison & Video Logo
17 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
intermittent power off
  • Televison & Video
