20 Most Recent Panasonic CT-27G14 27" TV Questions & Answers
2answers
Fuse blows.
Please check for shorted diode or condenser at power section.
12/16/2018 2:19:54 PM • Panasonic... • Answered on Dec 16, 2018
manual
10 fine white lines at top of tv screen
replace capacitor at vertical section
10/7/2013 10:03:41 AM • Panasonic... • Answered on Oct 07, 2013
Picture bounce
I think that maybe your horizontal hold is messed up. If there is anyway you can change it with a button or dial or something on the TV that would do it but if there isn't one then there is nothing you can do but to take it to a repairman but it is really expensive. You'll probably spend more on fixing it than you for the TV itself.You're better of to get a new television.
5/10/2012 3:33:24 AM • Panasonic... • Answered on May 10, 2012
Universal remote code for a panasonic ct-27g14a
Two things you can do:GOOGLE THE NUMBER OR MODEL OF THE REMOTE AND LOOK FOR THE INSTRUCTIONS FOR PROGRAMMING IT.GOOGLE THE MODEL NUMBER ON THE REAR OF THE TV WITH THE WORD REMOTE AFTER IT FOR A DIRECT REPLACEMENT.LET ME KNOW IF YOU NEED HELP
3/15/2012 3:34:20 PM • Panasonic... • Answered on Mar 15, 2012
27" (diagonal screen) Panasonic regular
It will be good to check the capacitor on the +B voltage that goes to the power section in the main board. A filter capacitor of about 47mF/160 V can be defective.
Next check the capacitor on the HT line to the grid-22mf/250V replace.
If possible loop on capacitors in the horizontal section particulary the IC.
Now the tip I can offer:
If the fault occurs on heating shcek out htis area to confirm and isolate the component.
But finally I understand that when you press any key the picture is good.If so check the memory IC/cmos IC in this section for logic control, it might be having a switching fault, a conflict or the video noise is coming on in default but goes off in the data selection mode. Do a soldering around this section on the IC , capacitor and see if the fault goes off or becomes irregular when this section is heated, if so there is a semiconductor producing this noise error .
So start from the begining so that we have a clean voltage inside.
I hope my advice helps.
8/23/2010 12:51:59 PM • Panasonic... • Answered on Aug 23, 2010
I bought a panasonic model ct-27g14a tv from a
Sorry,u must have it orignal codes,there noway to unlock secrect personal codes.U push the channels + or - buttons manual controls couples times.Might get in the tv input.Hook up,use it with DVD player can watch DVD Disc thought.Sorry, you probally only can watch shows rated Y for children only.
6/2/2010 4:13:12 AM • Panasonic... • Answered on Jun 02, 2010
Remote sensor on Panasonic CT-27G14 not
firt try with your cellular, put your cellular in camera and put your remote control in front of your cellular and press one botton, if you see a blincking ligth, your control is good and your IR sensor in the tv is bad.
4/27/2010 9:58:16 PM • Panasonic... • Answered on Apr 27, 2010
Digital or not
You will need a converter for this TV!
Please rate are answers to help keep this site free!
12/19/2008 6:57:51 PM • Panasonic... • Answered on Dec 19, 2008
Have slide picture on top.5"after a minutes stop at 2"
check for dry electrolitic capacitors around the vertical output section
10/2/2008 4:42:15 PM • Panasonic... • Answered on Oct 02, 2008
2answers
Horizontal white lines on top of screen
try to adjust the screen control in the flyback transformer. good luck
10/2/2008 2:39:04 PM • Panasonic... • Answered on Oct 02, 2008
PANASONIC CT-27D30B
Maybe the vertical IC output are damaged you need to replace him
9/19/2008 5:45:41 PM • Panasonic... • Answered on Sep 19, 2008
2answers
Panasonic TX-29AD2DPM Serial no LE-7511621
No Colin, Its not the Tube. The problem is a vertical sweep falure. it could be just a driver/output IC or could also have a problem In the sweep power supply where The voltage that supplys the B+ going to the vertical IC could also be defective. Its not a repair a user should attempt to do as it's soldered into place and you can get hurt if not experienced with these types of TV repairs. As to the cost It depense on how much you like the set and if you can find an honest repair person to do an honest job? Good Luck
3/14/2008 10:47:42 PM • Panasonic... • Answered on Mar 14, 2008
2answers
Panasonic TX14S2T
What are the symptoms? Is the set dead? Please clarify
model number from back of set...The red power light coming on means the AC fuse is OK, but the B+ fuse may be bad. If that
is true,check the horiz o/p xistor and get back to me....T.
10/28/2007 9:05:30 AM • Panasonic... • Answered on Oct 28, 2007
Tv
Check the transistors around the power supply, most likely there is one that is that is shoted out.
9/16/2007 11:15:46 PM • Panasonic... • Answered on Sep 16, 2007
TV Scratch
if you mean a scratch on the picture tube, sorry the only way would be to repalce the tube.
10/31/2006 6:47:36 PM • Panasonic... • Answered on Oct 31, 2006
TV Scratch
You can probable conceal the scratches but a complete repair is not possible,I've seen people who repair cracks in windshields using a special compound that dries clear but even that only conceals the scratches.I hope the scratches are not too deep and you can hardly see them when the set is on.
10/10/2006 3:50:47 PM • Panasonic... • Answered on Oct 10, 2006
Panasonic CT-27G14 27" TV Logo
26 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
remote sensor panasonic ct 27g14 not
  • Televison & Video
