20 Most Recent Panasonic CT-2006S 20" TV Questions & Answers
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Panasonic... • Answered on Jun 29, 2012
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Panasonic... • Answered on May 17, 2012
The vertical IC needs replaced and the electrolytic caps in the vertical section needs change. The vertical IC is mounted on a metal heat sink, and will have seven legs, and the [part no. is probably LA7838 vertical IC.
Panasonic... • Answered on Dec 24, 2010
Hi First check the vertical load resister it is high value.And then check vertical output capaciter.Finaly replace vrt ic.
thanking you
Panasonic... • Answered on Oct 03, 2010
hi! i have here a couple of codes for your tv, just try them, 1003, 1010, 1049, 1053, 1096, 1123, 1152, 1231, 1289, 1292, 1295, 1303, 1304, 1305, 1306, 1385, 1485, 1500, 1140, 1169, 1170, 1194, 1233, 1234, 1331, 1336, 1410, 1417, 1442, 1466, 1289, 2207, hope this helps!!!! goodluck!!!!
Panasonic... • Answered on Jun 07, 2010
I have an identical national tc 300 sp 3-in-1 unit. The power input for this set will automatically accept 120-220-240 VOLTS AC. The ac power pins in the 6-pin socket are the two horizontal pins immediately underneath the locating spiggot in the socket.
Panasonic... • Answered on Apr 15, 2021
The power LED blinking ten times is indicative of issues with the voltages on Sub 5V, Main 3.3V, DTV 9V or the Tuner Power and the board in question is the "A-Board". Also, make sure that your units fan and airflow is not inhibited.
Panasonic... • Answered on Mar 13, 2021
Sounds like T'Con board problem. It will be best to contact any service technician to make it sure. i don't think this is a user repairable fault. If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name and model of your set, in its search bar at the right side column, and press enter.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Panasonic... • Answered on Feb 26, 2021
Have you got the tv aerial connected into the dvd?
Panasonic... • Answered on Feb 16, 2021
The LED display does not show? I don't no what to do?please help
Panasonic... • Answered on Feb 09, 2021
Panasonic CT-2006S 20" TV Logo
7 questions posted
Top Panasonic Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
audio fine screen shows thin horizontal
  • Televison & Video
