20 Most Recent
Panasonic CT-36SL13 32" TV Questions & Answers
Tv shuts off tv/video doesnt work
that is a indication that a fault is about to occur, dont force that tv take it to a technician before it switches off completely, a power supply is supposed to be checked.
3/26/2009 8:06:31 AM •
Panasonic...
Answered
on Mar 26, 2009
Tv lock
PRESS POWER SWITCH AND ACTION FOR 3 SECOND
9/10/2008 5:34:38 PM •
Panasonic...
Answered
on Sep 10, 2008
32'' Panasonic TV, 4 yrs old, keeps blowing the fuse
Hi Mendi.
I had a similar problem, in that I could not find the proper fuse for my set. I bought a bit higher amp fuse from Radio Shack and it ended up blowing a couple months later. I've since pulled the TV down and replaced it with an LCD set, so I've solved my problem.
But, to address yours, I don't think the amp difference would not be the problem. Likely, there is a power issue on your set causing it to draw more amps and become out of specification. Using a higher amp fuse would buy you more 'capacity', but if its blowing those too (repeatedly), its likely a real problem in the set. I'm not a TV technician, so I can't tell you why. I'd suggest taking the thing in for service (cheaper than the house call) or if that is too expensive, looking at putting your money into a set that won't give you those problems. Or, just keep replacing the fuse until it doesn't fix the problem.
Sorry I cant help much more.
5/22/2008 7:37:46 PM •
Panasonic...
Answered
on May 22, 2008
Tv went dead
Sounds like it could be H.O.T which stands for horizontal output transistor or a fuse is possible. Another possibility is the FLYBACK transformer. Is there a local repair facility you could take it too? Keep me posted. Have a good day...Jay
4/24/2008 6:44:24 AM •
Panasonic...
Answered
on Apr 24, 2008
Is this?
This is from page 5 of the Operating Instructions:
TV set can
receive 480i signal only.
This means the television is NOT high definition, it is a STANDARD definition television.
3/15/2008 3:47:35 AM •
Panasonic...
Answered
on Mar 15, 2008
Loud noise then no power
I recommend having a service call done in the home due to the size and weight of the set. Is the set HDTV ready or compatable? IF it isn't i would consider a new tv. Good luck on your quest. Jay
2/1/2008 7:55:45 PM •
Panasonic...
Answered
on Feb 01, 2008
Panasonic CT-36SL13 Can't select video inputs
On a Panasonic to do a factory reset while the set is on press in on the power and action buttons on the front of the TV at the same time. In a few seconds the screen shouls go blank and come up with a screen that says "CHK" in the upper left hand corner. Once it does that press the action button again to clear the screen. You have now reset the TV to factory settings and will have to re-program the channel memory once again. Hope that works...
4/24/2007 5:04:23 PM •
Panasonic...
Answered
on Apr 24, 2007
Panasonic hds700tds playing audio no videos
- Check the Input Source: Make sure you have selected the correct input source on your TV for the device you are using. Use the remote control to cycle through the input options until you find the one connected to your video source.
- Check Video Connections: Ensure that all video cables (such as HDMI, component, or composite cables) are securely connected between your TV and the device you are trying to watch content from. A loose or faulty cable connection could result in a loss of video signal.
- Restart the TV and Video Source: Try restarting both your TV and the device you are trying to watch content from. Power off both devices, wait a few moments, and then power them back on. This can sometimes resolve temporary glitches or issues with the video signal.
- Check for Software Updates: Make sure your TV's firmware is up-to-date. Sometimes software updates can resolve compatibility issues or bugs that may be affecting video playback. Check the settings menu on your TV for an option to update the firmware, or visit the manufacturer's website for instructions on how to do so.
- Reset Video Settings: If you've made any changes to your TV's video settings, such as resolution or picture mode, try resetting them to their default values. This can sometimes resolve issues with video playback.
- Try a Different Device: If possible, try connecting a different device (such as a DVD player or gaming console) to your TV to see if the issue persists. This can help determine whether the problem lies with the TV itself or with the original device you were using.
- Contact Panasonic Support: If none of the above steps resolve the issue, it's possible there may be a hardware problem with your TV. In this case, you may need to contact Panasonic customer support for further assistance or to schedule a repair.
- Hope this helps
4/9/2024 11:43:10 PM •
Panasonic...
Answered
on Apr 09, 2024
I have a Panasonic 50-in flat screen TV a storm came by and knocked out my TV and my Yukon no breaker was off so did it come through the antenna please help
- Check the Power Cord: Ensure that the power cord is securely plugged into both the TV and the power outlet. Make sure there are no visible signs of damage to the power cord or the plug.
- Inspect the Power Outlet: Try plugging another electronic device (such as a lamp or a phone charger) into the same outlet to verify if it is functioning properly. If other devices work fine, then the issue is likely not with the power outlet.
- Check for Tripped Circuit Breakers: Check your circuit breaker or fuse box to see if a circuit breaker has been tripped or a fuse blown. If so, reset the circuit breaker or replace the fuse and try plugging in your TV again.
- Test with Different Power Source: If possible, try plugging your TV into a different power source altogether, such as a different room or building. This will help determine if the issue is specific to the power source you were previously using.
- Contact Panasonic Support: If none of the above steps resolve the issue and your TV still does not power on, it's likely that there is a hardware problem with the TV itself. In this case, you may need to contact Panasonic customer support for further assistance or to arrange for repairs. Be sure to provide them with details of the troubleshooting steps you've already taken.
Hope this helps
4/9/2024 7:56:16 PM •
Panasonic...
Answered
on Apr 09, 2024
