20 Most Recent HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E NVIDIA 9100 AM3 Motherboard (610074079576) Questions & Answers
You have a Memory (Ram) problem. Follow this it may help.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&product=3440615&docname=bph07107
HEWLETT-PACKARD... | Answered on Apr 09, 2014
You can purchase an efficient store visit this link HP System Board 513430 002 NP253 69001 MBD VIOLET GL8 New buy now!!!
Enjoy shopping
HEWLETT-PACKARD... | Answered on Apr 05, 2014
Before you give up check on ebay. If you do replace just make sure that the physical size is the same and that the replacement uses the same cpu and memory you have now. Otherwise you will be spending much more dinero.
HEWLETT-PACKARD... | Answered on Apr 02, 2014
Tip
Why choose HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E??
Things to be considered in choosing HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E
1. Processor and Memory upgraded
3. I/O Ports and Network
5. Clearing BIOS password
For details you can visit web site www.hpparts.us
on Apr 02, 2014 | HEWLETT-PACKARD HP Pegatron...
they are number one on the cables are red
HEWLETT-PACKARD... | Answered on Mar 24, 2014
IT DOES NOT MATTER.THE MAUFACTURES HAVE MADE THEM
BACK COMPATIBLE.
HEWLETT-PACKARD... | Answered on Dec 21, 2013
go to hp support download bios from there ok.
HEWLETT-PACKARD... | Answered on Nov 03, 2013
hi,
you may even find a new graphics card won't help. you are most likley suffering from an overheated northbridge. there not usually monitored for temp this is on the MB so, not good news as this will eventually go dead. and even re- greasing at this point won't help. however. by disassembling both the video card and northbridge heat sinks. you should find one of them pretty dried out.
GL
hope this helps
don't forget to vote for me
Thanks
Jamer
HEWLETT-PACKARD... | Answered on Mar 23, 2013
Did you test the power supply with a power supply tester? You may only have partial power or very low power. I would try a power supply from another pc, Then I would check the ram in another pc if possible one stick at a time or if no other machine :
I would try removing all the ram and try one stick at a time in a different slot each time till it boots and then try a different stick the same way. You could have a bad memory stick and or slot.
I think its the power supply first, a bad stick of ram second or a bad ram slot third and the motherboard last. I would try all my parts in another pc first before a buy another motherboard
inside bios
HEWLETT-PACKARD... | Answered on Feb 24, 2013
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is availible) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
HEWLETT-PACKARD... | Answered on Sep 30, 2012
Photo of the Asus M2N78-LA motherboard,
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01421635&dlc=en
This photo also shows the orientation (Direction), that the motherboard is sitting in a computer case.
To the very bottom right is the Front Panel header.
The front plastic panel of the computer is the Front Panel.
The area of pins on the motherboard that the cables, (Wires) from the Front Panel connect to, is the Front Panel header. ( F_PANEL )
The Front Panel header, is the black rectangular shaped plastic block, that is sitting vertically on the motherboard.
Has two columns of pins.
4 on the left side, 5 on the right side. Makes it look as though there is a pin missing, at the top left corner.
I'm going to number the pins.
Pins on the Left side starting at the Top, going down;
Pins 1, 3, 5, and 7.
Pins on the Right side starting at the Top, going down,
Pins 2, 4, 6, 8, and 10.
A) Pins 1 and 3 are for the Power On switch. (Power On button)
B) Pins 5 and 7 are for the Power On LED light.
Pin 7 is for the Positive ( + ) wire.
(If the LED light is dim, reverse the wires around)
C) Pins 4 and 6 are for a Reset switch, IF a Reset switch is used. (Reset button)
D) Pins 8 and 10 are for the HarDDrive activity LED light.
Pin 10 is for the Positive wire. ( + )
(If the HDD LED light is dim when operating, switch the wires around)
Pin 2 at the top Right is NOT used. (NC. Not Connected)
For additional questions please post in a Comment.
I am looking at a motherboard manual in PDF file form, for the Asus M2N78-LA motherboard.
Regards,
joecoolvette
HEWLETT-PACKARD... | Answered on Sep 03, 2011
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions, DE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs all electrical power and data to travel through every working device its and have an end so any faulty leads will end up with a computer error
make sure your ram and cmos battery are securely seated with no dust in sockets
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS
hope this will help
HEWLETT-PACKARD... | Answered on Jul 26, 2011
Newegg.com / Frys Electronics (frys.com) or buy.com are your best bets
HEWLETT-PACKARD... | Answered on Jun 05, 2011
HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E NVIDIA 9100 AM3 Motherboard (610074079576) Logo
31 questions posted
Top HEWLETT-PACKARD Computers & Internet Experts
Davit Mamyan
Davit Mamyan
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HEWLETT-PACKARD Computers & Internet
Most Popular Question
hp pavilion
  • Computers & Internet
