20 Most Recent Western Digital 2 TB SATA 6 GB/s 7200 RPM 64 MB Cache Bulk/OEM DESKTOP WD2002FAEX (Caviar... Hard Drive Questions & Answers
My hard drive is making
Any strange noise like excessive clicking, grinding, some weird sounds etc. actually indicate a failing hard drive.
Failing hard drives often show warning signs of their imminent demise. If you're lucky enough to see or hear one of these signs, stop what you're doing and immediately back up your data. They say prevention is better than cure so if your computer's hard disk is making some strange clicking sounds, BACK UP YOUR DATA IMMEDIATELY (As the drive is not operating smooth and may fail anytime).
After making backup of your important data on CD/DVD or External Drive, you may scan the drive for surface errors, format it and see if it works properly or not. It would be better if you seek professional assistance for examination of the disk.
Hard drives are mostly under warranty for at least one year. Claim warranty, if possible.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
9/20/2011 8:02:58 AM • Western Digital... • Answered on Sep 20, 2011
I am running Windows 7
When all drives are plugged in, is there any problem or conflict in Device Manager?
6/14/2011 3:39:15 AM • Western Digital... • Answered on Jun 14, 2011
My WD 6bg pocket HDD
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage your computer
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
4/8/2011 5:09:09 AM • Western Digital... • Answered on Apr 08, 2011
I ;have formatted the WD external drive and
You should not even try to install an operating system on an external drive. Windows looks at the "C" drive and installs programs to "C" drive. You are trying to put it on the "G" drive. You will have too many problems and wish you never had tried. Buy a larger main drive and partition it with two equal partitions. Then "Dual Boot". You will find how to do this on the internet. Just Google "Dual Booting".
9/9/2018 5:37:54 PM • Western Digital... • Answered on Sep 09, 2018
My hard drive won't initialize
Get TESTDISK and see if it is recognised, if so TestDisk has some tools that may help
2/6/2018 7:11:56 AM • Western Digital... • Answered on Feb 06, 2018
Sir, I have a Lenovo laptop.
If your HARD DRIVE was exposed to a magnetic field, this can happen.
Try a scandisck run.
Boot up in safe mode and run fix disk.
12/19/2017 12:50:04 AM • Western Digital... • Answered on Dec 19, 2017
Cannot format my WD 1TB external hard drive
The hard disk is having bad sectors on its first 3000 sectors.the bad sectors are caused by degradation of the platter of the hard disk.OR the factory area of the hard disk has certain files called SMART, G -LIST and other log files.Unless one empties those log files with a good tool , one cant format ones hard disk.
11/27/2017 4:26:43 AM • Western Digital... • Answered on Nov 27, 2017
Not detecting, beeping
This is likely a couple problems; 1. The hard drive is dying or is dead. You're looking at hardware recovery if this is the case. There are some tools such as Spinrite that might be able to recover the disk. (GRCHard drive data recovery software) 2. The power supply on the computer/laptop is not functioning as well as it used to. Try using another PC to see if there's any difference in results.
11/15/2017 9:57:20 PM • Western Digital... • Answered on Nov 15, 2017
Why is not my WD500 eSata hard drive doing nothing after it is connected via a USB cable to my laptop?
Download testdisk and run it to see if it recognised in the list. If so use the intel option to find a boot sector
10/11/2017 9:24:46 AM • Western Digital... • Answered on Oct 11, 2017
Western digital 2tb my passport keeps flashing; not detected
Remove the drive from the external case it is in and connect directly to your computer - see if the bios recognizes it. If so, the OS will do so also and you can access it. Also means the electronics of the external case are no good. If not recognized in other machine, the hard drive has gone to hard drive heaven and needs to be replaced.
9/9/2017 1:29:49 AM • Western Digital... • Answered on Sep 09, 2017
0answers
0answers
Western Digital 2 TB SATA 6 GB/s 7200 RPM 64 MB Cache Bulk/OEM DESKTOP WD2002FAEX (Caviar... Hard Drive Logo
5 questions posted
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Western Digital Computers & Internet
Most Popular Question
am running windows 7
  • Computers & Internet
