20 Most Recent ASUS K52F Notebook Questions & Answers
it should have worked when you took the battrey out
ASUS K52F... | Answered on Mar 29, 2015
enter the asus download site, choose your model and OS-version, download the drivers you need.
ASUS K52F... | Answered on Oct 21, 2014
I didn't see the stereo mix feature in this model, so maybe it is not exist.
ASUS K52F... | Answered on Mar 01, 2014
My laptop don't open it up shows error 0cx000000f
ASUS K52F... | Answered on Feb 26, 2014
Press F8 when starting up (May take a few tries to get it right) and take the "repair my computer" option
ASUS K52F... | Answered on Jan 25, 2014
Try F9 during boot.. I doubt you repartitioned that small partition when you reformatted the main partition of the drive. Then again, the F9 function might not work anymore, even though the partition is still intact.. From Asus Support:
Using the Recovery Partition(on selected models)
1. Press < F9 > during bootup.
2. Press [Enter] to select Windows Setup [EMS Enabled].
3. Select the language you want to recover and click Next.
4. Read the ASUS Preload Wizard messages and click Next.
5. Select a partition option and click Next. Partition options:
Recover Windows to first partition only.
This option deletes only the first partition and allows you to keep other partitions, and to create a new system partition as drive "C".
Recover Windows to entire HD.
This option deletes all partitions from your hard disk drive and creates a new system partition as drive "C".
Recover Windows to entire HD with two partitions.
This option deletes all partitions from your hard drive and creates two new partitions "C" (25%) and "D" (75%).
6. Follow the onscreen instructions to complete the recovery process.
ASUS K52F... | Answered on Dec 15, 2013
when you get a base system device in the other devices category in device manager it usually means that either the chipset drive has not been installed or a lot of the time it's the sd card reader driver.
ASUS K52F... | Answered on Nov 06, 2013
Turn on your computer and locate the Wi-Fi icon.
This could be located on the upper row on a laptop keyboard it should have a key something like (((.))) press it on
The internet connection is located in the system tray in the bottom-right corner of the screen.
The icon looks like a series of rectangles that increase in size from left to right.
Right-click the Wi-Fi icon and select "Connect to a network." You will see a list of available wireless networks.
Choose a Wi-Fi network you want to connect to and select "Connect."
Enter the password into the password text box if a password is required.
If a password is not required, you will automatically connect to the Wi-Fi network.
Click "OK."
ASUS K52F... | Answered on Nov 29, 2012
Try the sensitivity adjustment on your touchpad. I have never heard of a AC cord replacement doing that, will, you live and you learn, I suppose.
ASUS K52F... | Answered on Nov 23, 2012
Did the Mbox 2 ever work with your notebook? If not, then likely you just have not loaded the driver for it yet. A midi interface and mixer is not going to work just by plugging it in. It requires downloading the right software driver for the operating system you are using.
http://download.cnet.com/Digidesign-Mbox-2-Firmware-Updater/3000-18493_4-81231.html
ASUS K52F... | Answered on Oct 31, 2012
Try re-installing your wireless LAN driver or updating it on the internet.
Thank You.
ASUS K52F... | Answered on Jun 25, 2012
Okay, it could be two things, 1.) Your graphics card is either overheated or going out. 2.) it's possible you have a messed up display screen. I'd try looking at your computer display settings and see if you can calibrate the color on your screen to see if it helps or not.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
ASUS K52F... | Answered on Jun 05, 2012
Hi kunal24april...
You could have corrupted audio and or video drivers because of a recent download, or update/s.
I recommend that you go to the webpage and download and install the newest drivers possible for your laptop. http://drp.su/drivers/notebooks/?v=ASUS&m=K52F&id=175&l=en
You can also try this solution first:
To use your webcam:
Click on Start >Control panel>hardware and sound >device manager>imaging devices>
web cam....Check to see that it is enabled.
Please take time to rate me thumbs up
ASUS K52F... | Answered on Sep 08, 2011
Try here: http://www.asus.com/Notebooks/Versatile_Performance/K52F/#download Make sure your on the download tab, then select your OS. After that at the bottom should be the operating manual(s).You will need abobe reader, if you don't have it.
ASUS K52F... | Answered on May 17, 2011
There is a way in Control Panel, goto "MOUSE" select the pointers tab then you can adjust the speed where you like it!
ASUS K52F... | Answered on Feb 20, 2011
ASUS K52F Notebook Logo
36 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
K ASUS
  • K ASUS
Most Popular Question
factory restore
  • Computers & Internet
