20 Most Recent Panasonic DVD-RV26 DVD Player Questions & Answers
try a paper clip opened and put on dvd door hole (small hole), and push slowly the paperclip inside and realease the dvd door to open, normaly is a defective dvd laser mec. and needs to be replaced. send to repair
Panasonic... | Answered on Mar 17, 2013
Hi
Thanks for using FixYa. There are the following two methods to make it region free---
Method 1:
No disc in tray; Press STOP; Press SET-UP: KEY IN 3, 8, 8, 8, 3 then 0 for zone free
Method 2:
1. Remove DVD/CD from your drive.
2. Press the following keys on your remote: [Setup] [1] [>=10] [6] [4] [3] [8]
3. A new menu option will appear – named other followed by four stars. Use Codes: 3192 -> Multi-Region Enable
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Panasonic... | Answered on Jun 26, 2010
moz-screenshot.pngmoz-screenshot-1.pngThis is what i was able to gather for you.
H and than the numbers is the message:
Trouble is likely to have occured. the number following "H" differs depending on the status of the player.
Press {POWER} to switch the player to stand by mode and then back on. alternatively, press [POWER] to switch the player to the stand by mode, disconnect the AC power supply cord, and then reconnect it.
If the error message fails to be cleared even with this action being taken, you will need to ask a technician to repair the player.
you may also be able to call
1-800-211-PANA (7262)
for more troubleshooting and or to find the closest repair retailer.
Panasonic... | Answered on Dec 27, 2009
From the information I found, it does not have an ATSC tuner that you need to pick up the digital over the air TV signals. You will need one that does, check this page: http://www.ezdigitaltv.com/Digital_Recorders.html
Panasonic... | Answered on Jul 20, 2009
The spindle motor is defective.
Panasonic... | Answered on May 12, 2009
Laser is probebly goin bad and can't read. try putting a music Cd in. If it can play the music CD but not the DVD it's the laser.
Panasonic... | Answered on Apr 10, 2009
That's the spindle motor and it has to be replaced to solve the problem.
Panasonic... | Answered on Mar 28, 2008
Probably power supply failure
Panasonic... | Answered on Nov 11, 2020
The MENU button might be only on the remote control.
Panasonic... | Answered on Nov 10, 2020
Contact Shaw directly to inquire about applicable codes.
Panasonic... | Answered on Nov 02, 2020
The power supply is failing.
Panasonic... | Answered on Oct 30, 2020
Remove the attaching hardware
After the TV is turned on, is the power indicator on?
If you need tv parts you can link to https://www.abctay.com to search the tv parts number.
Panasonic... | Answered on Oct 16, 2020
Panasonic DVD-RV26 DVD Player Logo
14 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
h02 stop
  • Televison & Video
