20 Most Recent Panasonic PV-D734S DVD Player/VCR Questions & Answers
You need to convert the .avi files to the MPEG format with software. Just renaming the file will not work.
Panasonic... • Answered on Nov 14, 2019
The low humming sound is the motor that opens and closes the drawer. It is moving, but the movement is not being transferred to the door by a pulley, a belt or a gear, When you open the drawer completely, it should stop. When the drawer is closed completely it continues to run until the disc is in the proper position to play. As long as that motor is running the DVD will not work because the disc is not in the proper position,
Panasonic... • Answered on Feb 03, 2018
Please check and see if the link helps to get you the codes for the remote.
remote codes
Panasonic... • Answered on Jan 10, 2011
Repair it ur self,if u can,not than buy a new one,this things are cheap these days.The shop,probally cost the same to the repair priced as a new on.Check the motor that open the tray door,see if that motor is spinning?The motor that open the tray door,might be dead.Tries unplug,replug it an hour later,see if the thing reset itself.Might work again.
Panasonic... • Answered on Oct 19, 2010
This is for code f489 as well as f498 F498 means a problem with flash eprom IC; meaning that unit is unable to read the basic instructions from the eprom IC. Can be cuased by several; may simply be a "bad connection issue" at the eprom Ic or somwhere in the Bus line--defective Ic or corrupted information which may or may not be recovered with a "service recovery" disc.(not an end user procedure) First step; try resoldering Eprom ic being careful not to bridge pins. second would be to take the unit to a AUTHORIZED ONLY repair shop for a firmware or eeprom update. Good Luck
Panasonic... • Answered on May 24, 2006
Though the 4k Blu-ray player prototype is released in 2015 CES but there isn't that much information for the price and specific launch date we can get from Panasonic. And as I know, the 4K Blu-ray is supposed to come before 2015 Christmas. Too late, huh... So let say the best for now is still watching a good movie with Macgo Blu-ray Player. By the way, it has updated to support 4K.
Panasonic... • Answered on May 12, 2021
It is a CCD Remote Control Closed Caption Decoder https://www.ebay.ca/itm/124703762639?oid=363341823704 Nothing about manuals https://www.google.com/search?q=Sansui+Orion+076n0dw130+remote+control Buy a remote that is actually made for you Panasonic Model, an exact copy of the original called a facsimile remote. https://www.google.com/search?q=panasonic+tv+remote+control ..
Panasonic... • Answered on May 02, 2021
I have an identical national tc 300 sp 3-in-1 unit. The power input for this set will automatically accept 120-220-240 VOLTS AC. The ac power pins in the 6-pin socket are the two horizontal pins immediately underneath the locating spiggot in the socket.
Panasonic... • Answered on Apr 15, 2021
The power LED blinking ten times is indicative of issues with the voltages on Sub 5V, Main 3.3V, DTV 9V or the Tuner Power and the board in question is the "A-Board". Also, make sure that your units fan and airflow is not inhibited.
Panasonic... • Answered on Mar 13, 2021
Sounds like T'Con board problem. It will be best to contact any service technician to make it sure. i don't think this is a user repairable fault. If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name and model of your set, in its search bar at the right side column, and press enter.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Panasonic... • Answered on Feb 26, 2021
Have you got the tv aerial connected into the dvd?
Panasonic... • Answered on Feb 16, 2021
Panasonic PV-D734S DVD Player/VCR Logo
11 questions posted
Top Panasonic Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
faut f489
  • Televison & Video
