20 Most Recent
Panasonic PVD4744 DVD Player/VCR Questions & Answers
Will not play any DVD
I may have bad news for you. Here's my story with the PVD4744S.
I watched over an hour of a DVD-video disc one night, no problems. The next night, I played only the intro; then the DVD player gave a message, "This type of disc cannot be played. Please insert another disc." Thereafter, I couldn't play any of several DVDs.
The manual gives little help:
http://service.us.panasonic.com/OPERMANPDF/PVD4744.PDF
My disappointment is exacerbated by the declining availability of DVD/VHS players with an RF modulator. Maybe Panasonic should create a repair kit for aging devices.
9/30/2019 2:27:25 AM •
Panasonic...
Answered
on Sep 30, 2019
PANASONIC VCR/DVD TV
If you have sound knoledge in electronics, and experience to repair electronic printed circuit boards, you can troublehoot the problem to your player. The power supply regulator board should be troubleshooted. In most cases, this board has to be replaced as card basis.
5/17/2012 2:20:52 AM •
Panasonic...
Answered
on May 17, 2012
How can i fix my vcr dvd deck when i play the vcr it doesnt show
It really depends on the problem. I assume since you used a head cleaning device that the tapes are playing, but not clear correct?
Although tape cleaners like the one you used can help, they are only useful for minor problems and when used on a regular basis.
To really clean your VCR head completely you will need to remove the outer shell. After you have the cover off you will be able to see the reader head. Using Q-tips and rubbing alcohol wipe the surface clean and wipe lightly. You should be able to see a bit of discoloration on the Q-tip. Make sure to wipe off any residue with a clean dry Q-tip. While your inside blow off any dust that might be on the laser on the DVD player.
Hope this helps. Please let me know if you need anything more regarding this.
11/23/2009 1:52:22 AM •
Panasonic...
Answered
on Nov 23, 2009
Power outage
I bet you $120.00 you did not have a 1000VA UPS on it. If I was right, you can pay me now, and I can send you one.
You need a new TDVD-VCR.....They are so cheap now to replace...just replace it.
The thinner they are the faster they blow...by the way they have a computer in there. You are lucky nothing else blew
9/11/2009 12:58:21 PM •
Panasonic...
Answered
on Sep 11, 2009
DVD does not read DVD-r format disc
have you use a dvd-r format before? somes dvd dosent run in that format, but if yes then dont spend too much money in it becouses is a low cost one, try cleaning it with a cleaning cd, if is a bad chip(Ic) or the reading unit any way wll cost you a lot to repair and thats no bussines....good luck
8/6/2006 11:49:16 PM •
Panasonic...
Answered
on Aug 06, 2006
DVD player does not read DVD-r format disc
8/6/2006 11:46:29 PM •
Panasonic...
Answered
on Aug 06, 2006
How to reset lamp for Panasonic PT-vx400nt?
Turn off and unplug the projector.
Locate the lamp cover on the projector.
Remove the lamp cover.
Take out the old lamp.
Insert the new lamp.
Replace the lamp cover.
Reset the lamp hours:
Press the Enter button to display the "Option" menu.
Use the 5 or 6 button to select "Lamp Runtime".
Press and hold the Enter button for approximately 3 seconds.
The "Lamp Runtime" will change to "Time Reset [Power Off]".
Turn off the power and disconnect the power cord.
Finally, plug in and turn on the projector.
Remember to consult your projector's operating instructions manual for specific details and safety precautions.
How to change Panasonic vx 400 xga projector lamp change or replace (youtube.com)
2/17/2024 12:59:14 AM •
Panasonic...
Answered
on Feb 17, 2024
