20 Most Recent Panasonic PV-M1349 Combo Questions & Answers
I find that sometimes you have to turn the antenna a little to receive more channels. Do you have a good booster? I gained an extra twenty to thirty channels by installing a good booster to my antenna.
Panasonic... | Answered on Sep 29, 2017
I am getting a big black box on tv and don't have remote how do I get if off on a pv-m1349
Panasonic... | Answered on Jul 17, 2014
switch tv to analogue tv and auto tune on tuning menu making sure sky is on. It should find it around channel 69. If quality poor then change output frequency to a lower channel. You do this with sky menu and instruction book. Info is changing RF output in book, or google it.
Panasonic... | Answered on May 07, 2014
The secret is that the VCR code turns the set on/off and the TV code controlls the volume...try this:
Program the Verizon remote AUX button using the panasonic VCR codes until it turns the set on/off, program the remote for TV using the panasonic TV codes until it controls volume, then program the STB button to control all 3... STB, TV, and AUX. If you are missing any VCR or TV funtions try another respective panasonic code until all functions are available.
Panasonic VCR codes are 1089, 0062, 0189, 0252, 0643, 1062.
Panasonic TV codes are 0277, 0078, 0677, 1437.
To figure this out, I had to use the "what if none of the codes worked" section and figured I'd try the VCR codes since the TV codes would not turn it on/off.
Good Luck!
Panasonic... | Answered on Sep 04, 2012
This is what I did:
- go to the Main Menu
- select TV
- on TV menu change the INPUT from LINE to TUNER
That's it!!
Stay Blessed.
Panasonic... | Answered on Jul 30, 2009
UHF is only the higher air channels, all you have to do is put on cable and scan.
Panasonic... | Answered on Feb 27, 2009
if u hav a remot for it it shoud hav a screen ajust. ther is a pictur of a sun press it 2 times. if that dosnt work press it agn
Panasonic... | Answered on Aug 06, 2007
First you need to check if your set is in the cable mode and not antena mode,if the set is in cable make sure is in the standard cable mode and not another type of cable like HRC,if it is change it and try the autoprogram to set the available channels.I hope it helps.
Panasonic... | Answered on Sep 13, 2006
Disconnect the power source and allow to sit for several minutes.
Remove and reconnect the aerial or antenna connections and reconnect. Power unit on and run a New Channel search from aerial only.
Panasonic... | Answered 2 days ago
Ask Shaw. Applicable codes would be in the remote control
Panasonic... | Answered on Sep 21, 2020
MANY REPAIR SHOPS GIVE FREE ESTIMATES
sounds like it is overheating to me but I am not a tv repairman
Panasonic... | Answered on Sep 20, 2020
Have you checked the Input Source?
contact them direct
https://shop.panasonic.com/support-only/TC-P50ST50.html
Panasonic... | Answered on Sep 13, 2020
ask google for the code list for that make
Panasonic... | Answered on Sep 06, 2020
The main record/replay head should be spinning as soon as a tape is pushed into the slot and as the cassette engages with the spindles the sensor that disappears into the cassette will register the presence of a tape and the tape should spool out...
That is what is happening - I am not sure why it ejects. The mechanism is complex and the electronics that support the mechanism similarly so. There might be an electronic fault but a mechanical fault is more likely, especially if the unit hasn't been used for a while. The internals are a riot of rubber belts and wheels, solenoids and clutches and the risk of tape damage is very high if all those things aren't performing as they should and so rather than risk a tape the cassette is spat out when something isn't right.
The guys in the repair shop remove the cover and insert a special cassette that is an ordinary cassette that enough remains to fool the system into operating but the majority has been cut away. This allows them to closely observe the mechanism in action - the first step in finding the problem...
Panasonic... | Answered on Aug 28, 2020
Panasonic PV-M1349 Combo Logo
Popular Tags
10 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
tv says line channels work
  • Televison & Video
