20 Most Recent Panasonic PV-DF2700 27 in. TV/VCR/DVD Combo Questions & Answers
Some tv can't go into the tv menu without the remote,all colors/contrast functions setting are in the menu setting.Try website like Remotes.com to buy an original remote or very close to it.
Panasonic... | Answered on Feb 09, 2011
Hello, the tuner could be ready to go out entirely, but you can still view your cable TV through your Auxiliary input jacks(video/audio colored jacks) most of the cable boxes ave these outputs in the rear all you need is the RCA cable(yellow/red/white) and select the video input you want to use. The other solution is to replace the tuner. You can order one through www.partstore.com or directly from panasonic at their website www.panasonic.com.
Panasonic... | Answered on Nov 26, 2010
There is an easy way to check if a remote is working or not. Put new batteries and locate the small LED on its head. Its a small white diode but emits Infrared which humans cannot see.
Notice the two wires inside the 'bulb' are of different shape.
Now look at the LED through a digital camera of a mobile phone. The idea is that the camera sensor can 'see' the LED glow when a button is pressed and will show it glowing when you press any key on it. If it is not lighting up then probably the remote is faulty.
You can replace the IR diode yourself if you have soldering equipment and some skill. Purchase a new one at any electronics repair store where you can buy soldering equipment and solder it where the old one is. Be careful as the diode is polarized meaning you must solder the new one EXACTLY keeping in mind the shape of the filament.
There may be other faults also like disconnected leads or the pad dirty making key contact difficult. In worst case the IC inside may be damaged and it is not worth repair.
If you find the remote OK (the camera test is +ve) then its likely the problem is in the TV. There is a small sensor on the front to receive the signals from the remote and may become faulty.
And if you need to buy a new remote it is better to buy the original or a replacement (if original is unavailabl). There are 'universal' remotes also that claim to control most of the equipment in your house but please keep in mind that they may not work with your TV leaving you with a good useless remote and some waste cash.
Panasonic... | Answered on Mar 24, 2010
There are a few universal remote controls that you can use, I have 2 philips remotes that work. One is model SRU4106/27, I believe i purchased that last year at Target, the other I no longer have the instructions to and there is no model number on the remote, but if the label says dvr's the remote will probably work. It is nice to get one with an advance button that has an arrow on the button, because Replay tv of that model has a commercial skip that can be used vs fast forward on other dvrs. The remote that I gave the model number for does not have the advance button, but the other thinner gray remote does have it and I purchased that one at Best Buy, but haven't seen them there in a while. You can also find them on ebay, just search replay tv on the search bar...Good Luck!
Panasonic... | Answered on Feb 01, 2010
Usually its for the special features stuff on your tv
Panasonic... | Answered on Aug 23, 2009
Most universal remotes will not work with TV/DVD/VCR combos . Sorry!
Panasonic... | Answered on Mar 26, 2009
This is a failure of the vertical circuit. Usually this is either poor connections at the vertical IC or a defective IC. If you can solder, try resoldering the pins of the IC. If that fails to resolve the problem, replace the IC.
Keep me posted.
Dan
Panasonic... | Answered on Feb 16, 2009
You lost your vertical sweep. most likely the vertical output IC or a power supply source is the problem.
Panasonic... | Answered on Dec 30, 2008
it isnt your dvds it could be that your laser lens needs to be cleaned
Panasonic... | Answered on Aug 10, 2007
Hey Fy what do you mean by replacement lamp?? theres no such device in this set???The sets not turning on it could be a shorted horizontal output transistor and if thats been replaced and blown again then you probably have a bad flyback xformer. If thats what your refuring to then i dont have a clue what your saying as ythis set has only a picture tube??? Need more info please.
Panasonic... | Answered on Apr 30, 2006
what type of set is this??? theres no picture of it and the top of the product says its a panasonic pv-DF2700 27inch. Is it a projection set or ??More info please
Panasonic... | Answered on Apr 18, 2006
Remove the attaching hardware
Panasonic... | Answered 2 days ago
The code would be in your Dixon remote control if it is compatible with your Panasonic player.
Applicable code(s) would be found in a compatible remote control.
Panasonic PV-DF2700 27 in. TV/VCR/DVD Combo Logo
Popular Tags
19 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
picture panasonic pv df2700 flickers
  • Televison & Video
