20 Most Recent Panasonic PV-DF2703 Triple Play 27 in. TV/VCR/DVD Combo Questions & Answers
Same here! It would say something along the lines of "this type of disc cannot be played. please insert a different disc." it's the appropriate dvd region, i've tried all types of dvds, and it still won't work. the vhs and cd still works, it's just the dvd player that won't.
Panasonic... | Answered on Sep 30, 2019
Check and replace the laser pickup unit. It is faulty [Weak]. If you wish to get some details; visit the site linked here. Pull up older posts.
Panasonic... | Answered on Dec 28, 2017
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Panasonic... | Answered on Sep 23, 2013
5 digit code for the comcast red button silver remote is 21462 this pertains to Panasonic MODEL# PV-DF2704
Panasonic... | Answered on Jan 06, 2013
you will need a sdtv converter box and compatiable attenna to match before you will get over the air programing, you can get these from you loloca walmart for a resonable price
Panasonic... | Answered on Sep 25, 2012
Your lens needs replacement
Panasonic... | Answered on May 26, 2011
hello,
you have to open the back cover of the combo to clean the lens of the DVD with cotton bud dip slightly in a methylated spirit, if otherwise replace the drive of the DVD.
you can get a new DVD from the this site store.richspsxparts.com/wiiredvddr
hope this works
Panasonic... | Answered on Jun 01, 2010
defect in the power circuit you needs a tech to look on your set and repair it.good luck.
Panasonic... | Answered on Mar 01, 2010
if you dont have sound in the internal speakers ,or headphone jack if it has one ,try the audio outs to a surround system,if thats what you are using allready,replace the audio cord ,or try a diffrent surround system,most likely if no sound anywhere,the audio output transistor on the main board is toast,panasonic may sell you a schematic,10 bucks or so ,but you will still have to locate it on the board and replace it ,involves soldering,and tech skills,,if you or a friend have these skills it would be worth a shot,if not send for repair,or maybe think about a new tv,the repair could cost as much as the tv depending where you bring it,good luck i hope this helps you aloha from maui todd0708
Panasonic... | Answered on Oct 01, 2009
Some TV, depending on the model may not work, or not be fully functional if you use Universal remote.
If the TV has a blue screen it may be a source problem. Try connecting a DVD or a VCR, possibly through SCART cable that starts automatically
Also if the green light on TV is blinking and the TV has a blue screen, the TV may be in protect mode because of a fault.
Try unplugging the TV from main and plug it back, if that does not work, and changing connected source did not solve the problem, the TV may be faulty.
If you want to purchase and test an original remote, you can find one here: Panasonic PVDF2703 Replacement Remote Control.The remote will come with a One Year Money Back Guarantee.
Regards.
Panasonic... | Answered on Aug 14, 2009
1. Press the Menu button on your remote control 2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the TV.
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
Panasonic... | Answered on Nov 11, 2008
Salutations bachiche13,
It sounds like your "Text" feature of your closed captioning may be activated. It sounds like what you would want to do is go in to your television menu and select CC or Closed Captioning to mute or off.
Hope this helps.
Jon
Go Ahead. Use Us.
Panasonic... | Answered on May 21, 2008
Panasonic PV-DF2703 Triple Play 27 in. TV/VCR/DVD Combo Logo
Popular Tags
29 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
remote codes panasonic model pv df2704
  • Televison & Video
