20 Most Recent Zanussi ZFT710W Freezer Questions & Answers
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Zanussi ZFT710W... | Answered on Oct 04, 2015
I believe that a short circuit creates a defective light bulb inside the refrigerator or some other element in its circuit (door switch, lamp socket, wiring).
Dado
Zanussi Freezers | Answered on Dec 21, 2016
For such a procedure you should have knowledge and a lot of expensive work condition like:
- Vacuum pump
- Charging station
- Manifolds
- Recovery station
- Electronic charging scale
- Electronic leak detector or UV leak detector
and so on ......
The situation is further complicated by some of the new environmental gases which are explosive so you need to be qualified and trained person. It is best to leave that to the specialist or qualified service personnel.
Dado
Zanussi Freezers | Answered on Jan 16, 2015
Probably is switch for fast freezing mechanically defective.
Dado
temperature of the freezer will ensure the longterm
food.
Dado
Because it does not achieve the correct temperature (for example: -18 degrees centigrade).
For a more precise answer I need more information.
A lot of things may be incorrect:
- Doesn't work defrosting cycle
- The cooling fan is not working
- Too much ice on the evaporator battery
- Faulty thermostat or NTC sensor
- Faulty cooling system (gas leak)
- Compressor
- Electronic
Dado
It sounds like the door got shut when something in the jam and you may need to loosen the hinge, realign the door and tighten the door hinges again. Easier with 2 people but not impossible with 1.
Zanussi Freezers | Answered on Mar 03, 2014
the unit was still wet inside when you switched on the fast freeze,hence the frost and ice.
Zanussi Freezers | Answered on Jan 21, 2013
Hello....Sounds to me like the fridge is getting low on refridgerant gas...If it is an older unit...it may have developed a leak over time and may just need a recharge.Get a quote from a repairman...most of the time..it is not very expensive to fix unless there is a problem with the compressor....I hope this was helpful....PEACE....
Zanussi Freezers | Answered on Jan 25, 2012
There should only be 2 wires for compressor operation, (brown and white or blue and white), it you only have 2 posts with wires to them on your thermostat, take the wires off the posts and join them, if compressor is good, it will start but do this with GREAT CARE, exposed wires are dangerous and be sure to disconect the power from the wall before and after doing the above, good luck. Russ
Zanussi Freezers | Answered on May 08, 2011
Zanussi ZFT710W Freezer Logo
2 questions posted
Top Zanussi Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Kami
ray gallant
Are you a Zanussi Freezer Expert? Answer questions, earn points and help others
View Most Popular
Zanussi Freezers
  • Zanussi Freezers
Most Popular Question
freezer different code number zft710fw
  • Freezers
