20 Most Recent Frigidaire FVE145FF Upright Freezer Questions & Answers
Door left open for about 90 mins on freezer now
Good Morning Martin, thank you for your post! If the temperature of food rises to an unsafe level, the red light will glow. First, deactivate the alarm to the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the unit. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
10/8/2013 11:13:38 AM • Frigidaire... • Answered on Oct 08, 2013
Frigidaire FFU1424DW16 upright freezer. What is the cubic feet of it?
Question edited for clarity and add maker. Question moved to correct category. 16 cubic feet for that series, the '16' in the model number. https://www.google.com/search?q=Frigidaire+FFU1424DW16+freezer+Cubic+feet ..
11/16/2023 3:43:26 AM • Frigidaire... • Answered on Nov 16, 2023
Frigidaire MFC20M4FW3 Freezer. What is the cubic feet of my freezer please?
Question edited for clarity. Question moved from Washing Machines category. It looks to be a standard 20 cubic feet freezer and has '20' in its model number. you can also measure it internally in feet and multiply length x width x depth. https://www.google.com/search?q=frigidaire+mfc20m4fw3+review ..
4/15/2023 6:41:20 PM • Frigidaire... • Answered on Apr 15, 2023
2008 Frigidaire upright freezer giving error code -H9. Can you please help me with this? No notation in manual.
The error code -H9 on a Frigidaire upright freezer typically indicates a communication error between the control board and the display board. To troubleshoot this issue, try unplugging the freezer for a few minutes, then plugging it back in to see if the error code clears. If the error persists, it may be necessary to replace one or both of the boards. Contact a qualified appliance repair technician for further assistance.
2/14/2023 6:48:44 AM • Frigidaire... • Answered on Feb 14, 2023
What is the cubic ft.for a Frigidaire stand up freezer model MFU23BW4
According to the Frigidaire website, the cubic feet for the Frigidaire stand up freezer model MFU23BW4 is 23 cubic feet.
1/6/2023 6:19:01 PM • Frigidaire... • Answered on Jan 06, 2023
2answers
High temp code on my frigidaire upright freezer. What is this and how do I fix it?
Many reasons why it may be loosing temperature. Such as Defrost problem, fan not running, sealed system problem, compressor problem
11/2/2022 6:39:37 PM • Frigidaire... • Answered on Nov 02, 2022
2answers
My frigidaire chest freezer model FFFC07m2kw stopped working and all food thawed inside . we cleaned it out and since when we plug it up it comes on for 5 to 10 seconds and then stops .
if have an amp probe [multi-meter] when turns on check amp draw on motor ----motor failure ---thermostat failure --no freon
8/28/2022 9:00:34 AM • Frigidaire... • Answered on Aug 28, 2022
2answers
My Frigidaire up right freezer is showing an error code "FF" and is beeping. What is the issue?
Hey friend, thanks for your inquiry!
Within your Frigidaire freezer the error code "FF" stands for freezer failure. I would perform a reset on your appliance which can be done by either unplugging the power cord or flipping the household circuit breaker. Once the freezer has come back on you should be able to push the "Down" button three times to start it back up.
If that does not correct the issue Please respond back I would like to assist you with any additional information. Hope this helps to some degree. -Matt
8/7/2022 8:10:40 AM • Frigidaire... • Answered on Aug 07, 2022
I have just defrosted my Frigidaire elite larder freezer. The red and orange lights are on but not the green There is power as I can hear it running
It is under the temperature is has been set to. It should stabilise in about 4 hours..
6/4/2022 3:10:00 PM • Frigidaire... • Answered on Jun 04, 2022
My Frigidaire upright freezer has a big gap on the bottom left corner and the top left corner is hitting the freezer body!
Question edited for clarity. Question moved from Cars and Trucks!! This has all the hallmarks of a fridge that may be overloaded with weight, on an uneven floor with misaligned levelling feet. Cut a piece of 1" marine plywood 1" bigger than the width and depth. Empty the freezer and put it on the plywood. Level the feet using a spirit level left to right and a fore and aft. Make sure it doesn't rock. Loosen the door hinges and centre the door. Fill the freezer back up.
5/25/2022 2:26:45 AM • Frigidaire... • Answered on May 25, 2022
Model FRF170FF. Why is alarm light blinking with no warning bleep?
in settings alarm might be turned off
2/28/2021 10:36:08 AM • Frigidaire... • Answered on Feb 28, 2021
2answers
Frigidaire 13.7 cu ft freezer lost power during a winter storm. Display comes on but not the compressor.
Disconnect the power again for 5 minutes and then put a dinner knife across the two mains plug pins. Then plug it back in. If it doesn't work after that you need an engineer. The main board or other components may have been damaged by a power spike when the power cut.
2/28/2021 10:32:12 AM • Frigidaire... • Answered on Feb 28, 2021
2answers
I TRANSPORTED A REFRIGERATOR FROM HOUSTON TO
sound like the condenser fan motor by the compressor has stopped and the not allowing the proper cooling check that also you should have waited at least 6 hr upright before starting the unit
10/23/2019 10:37:05 AM • Frigidaire... • Answered on Oct 23, 2019
Does Frigidaire 11 cu ft need back ventilation
Always at least and inch or two away from wall. consult your installation instructions or use guide for info
6/24/2019 1:49:54 PM • Frigidaire... • Answered on Jun 24, 2019
Where is the temperature control knob on Frigidaire upright freezer model #CFFH17F1RW
The temperature control is located inside the freezer on upright models, and onthe left outside wall on chest models. The temperature is factory preset to providesatisfactory food storage temperatures.
However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If acolder temperature is desired, turn the temperature control knob toward COLD-EST and allow several hours for temperatures to stabilize between adjustments
6/16/2019 4:22:25 PM • Frigidaire... • Answered on Jun 16, 2019
Frigidaire FVE145FF Upright Freezer Logo
2 questions posted
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Freezers
  • Frigidaire Freezers
Most Popular Question
door left open about 90 mins freezer now
  • Freezers
