20 Most Recent Bush BAF55143W Freezer Questions & Answers
Why is my freezer not freezing
I had this happen to my freezer and I had to install a fan in the freezer by a repair man and then it worked like brand new.
7/18/2012 11:49:03 PM • Bush BAF55143W... • Answered on Jul 18, 2012
I have a Bush Tall
Your fan unit is blocked, draws freezer air from freezer, may be defrost element or defrost timer, needs service machanic, sorry. Russ
8/23/2011 12:52:15 PM • Bush BAF55143W... • Answered on Aug 23, 2011
2answers
Bush Freezer M5085UCFR stopped working?
Si su Bush Freezer M5085UCFR dej? de funcionar, hay varias cosas que debe comprobar. Primero, aseg?rese de que est? conectado correctamente a una toma de corriente segura. Si est? conectado correctamente, compruebe que la luz interior est? encendida. Si la luz interior est? apagada, desenchufe el congelador y desconecte la tapa del termostato. Limpie los contactos con un pa?o h?medo y vuelva a colocar la tapa del termostato. Si la luz interior sigue apagada, sugerimos llamar a un t?cnico en refrigeraci?n para reparar su Bush Freezer M5085UCFR
1/6/2023 1:07:51 AM • Bush Freezers • Answered on Jan 06, 2023
I have a bush bcf99l chest freezer. The orange alarm light is on, what does it hat mean.?
Means temps are too high most likely
2/1/2019 4:00:39 PM • Bush Freezers • Answered on Feb 01, 2019
Just bought a bush bcf99l chest freezer. The red run (compressor) light has stayed on and the front of the freezer is quite hot to the touch is this normal?
normal if it is the outside surface that is warm as that is the condenser exchanging the heat through a panel the compressor will run for a period until the heat inside the compartment is brought down Experience has proved that to get any fridge /freezer to work well , place a bowel of water in first as that gives a heat source to cool down and it will do so more quickly that just an empty volume
6/14/2018 11:00:28 PM • Bush Freezers • Answered on Jun 14, 2018
I bought a bush fridge freezer 2 years ago and it just stopped working i then had to buy another one is there anything i can do
Hello John; My name is Peter. I am a retired field service refrigeration technician. There is nothing I enjoyed more than getting a service call on a refrigerator freezer. There are so few parts and the parts are easy to access. Other than a premature compressor failure, you could have gone into a site such as this, explained the problem, and have someone such as I walk you through it.
5/11/2015 6:19:34 PM • Bush Freezers • Answered on May 11, 2015
0answers
Compressor gets very hot
The compressor has a start device that could be the problem. If you remove it it should not rattle if it does it is very likely the problem. If it doesn't rattle then it could be your compressor. Check the start device first. it is located directly on the side of the compressor. and is easy to remove and install anoter.
4/13/2014 8:49:00 PM • Bush Freezers • Answered on Apr 13, 2014
0answers
Bush fridge freezers
Order parts online through freezer parts supplier.
10/18/2013 7:38:32 PM • Bush Freezers • Answered on Oct 18, 2013
How do I remove shelves if they are attached to tubes connected to the back inside of the upright freezer
you do not leave them alone they may have refrigerant flowing through them. look in your owners manual/instructions for more info.
4/14/2024 10:55:01 PM • Freezers • Answered on Apr 14, 2024
Norfrost C6AEW Chest Freezer. Wiring help please.
Question edited for clarity and add CAPS. It seems to be a common occurrence on that model due to bad design. https://www.fixya.com/support/t17110008-norfrost_c6aew_chest_freezer_compressor Norfrost is owned by Ebac. Contact their customer service. https://www.johnogroat-journal.co.uk/news/caithness-freezer-name-lives-on-in-england-170710/ https://www.ebac.com/support/customer-service Another way would be to study the wiring as it is pretty standard. The video may help. https://www.google.com/search?q=freezer+wiring+diagram You may be able to freeze this video to note the wiring, although this only shows the thermostat wiring and is a bit fuzzy. Also an refrigeration appliance technician would know the wiring by heart and take 20 minutes maximum to work it out.
2/11/2024 5:45:01 PM • Freezers • Answered on Feb 11, 2024
2answers
Norfrost c6aew chest freezer compressor wiring
Hey. I dont suppose you figured out where the wires went all all? I've done the same thing ???? img-20240210-wa0019-hnmqxmichaytgjvoydy3hl3m-d-0.jpg img-20240210-wa0018-hnmqxmichaytgjvoydy3hl3m-d-1.jpg img-20240210-wa0020-hnmqxmichaytgjvoydy3hl3m-d-2.jpg
2/11/2024 12:01:33 PM • Freezers • Answered on Feb 11, 2024
Tappan TFC13M0AW1 Chest Freezer. What part should I replace?
Question edited to add maker! All questions need 'make model (what it is) as first three words. That is an overheating fault. Replace the fluff with no fluff. Make sure the condenser coils are free of dust and there is good airflow Or It is low on refrigerant gas and you need a service tech.. ..
2/3/2024 5:25:13 AM • Freezers • Answered on Feb 03, 2024
Cubic feet of a fridgeadare chest freezer- FFC13K2CW1
The Frigidaire FFC13K2CW1 chest freezer has a capacity of 12.8 cubic feet. More info: https://www.partselect.com/Models/FFC13K2CW1/
1/22/2024 2:51:52 PM • Freezers • Answered on Jan 22, 2024
One of the drawers in my upright freezer BRADA MF-305 broke. Is it possible to replace it please?
Question edited for clarity. Duplicate question deleted. Refresh page to see you question. This is not a make I know. Things like drawers are usually readily available. This link may work better where you are located. https://www.google.com/search?q=BRADA+MF-305+parts Generic Drawer replacements https://www.google.ca/search?q=freezer+drawer+replacement&sca_esv=580628691&tbm=isch&sxsrf=AM9HkKk2I1HuWqUimTZskQkh3tRH3AJ6rA:1699481832834&source=lnms&sa=X&ved=2ahUKEwiZ0MqXt7WCAxUwL1kFHUrtBG0Q_AUoAnoECAIQBA&biw=1920&bih=919&dpr=1 ..
11/8/2023 10:18:51 PM • Freezers • Answered on Nov 08, 2023
My chest freezer will not freeze food on top layer or in basket
Is it on Economy Mode? That only chills the bottom area. Check the condenser fins are cleaned of dust. That needs doing every 6 months. Or it needs refrigerant gas. ..
10/5/2023 3:35:25 AM • Freezers • Answered on Oct 05, 2023
Bush BAF55143W Freezer Logo
Popular Tags
7 questions posted
Top Bush Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Bush Freezer Expert? Answer questions, earn points and help others
View Most Popular
Bush Freezers
  • Bush Freezers
Most Popular Question
  • Freezers
