20 Most Recent
Bush CF143GB Chest Freezer Questions & Answers
Bush Freezer M5085UCFR stopped working?
Si su Bush Freezer M5085UCFR dej? de funcionar, hay varias cosas que debe comprobar. Primero, aseg?rese de que est? conectado correctamente a una toma de corriente segura. Si est? conectado correctamente, compruebe que la luz interior est? encendida. Si la luz interior est? apagada, desenchufe el congelador y desconecte la tapa del termostato. Limpie los contactos con un pa?o h?medo y vuelva a colocar la tapa del termostato. Si la luz interior sigue apagada, sugerimos llamar a un t?cnico en refrigeraci?n para reparar su Bush Freezer M5085UCFR
Compressor gets very hot
The compressor has a start device that could be the problem. If you remove it it should not rattle if it does it is very likely the problem. If it doesn't rattle then it could be your compressor. Check the start device first. it is located directly on the side of the compressor. and is easy to remove and install anoter.
Tappan TFC13M0AW1 Chest Freezer. What part should I replace?
Question edited to add maker! All questions need 'make model (what it is) as first three words.
That is an overheating fault. Replace the fluff with no fluff.
Make sure the condenser coils are free of dust and there is good airflow
Or
It is low on refrigerant gas and you need a service tech..
2/3/2024 5:25:13 AM •
Freezers
Answered
on Feb 03, 2024
