20 Most Recent Panasonic PT-51G53 51" Rear Projection Television Questions & Answers
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Panasonic... • Answered on Oct 24, 2013
If the color, brightness and contrast settings can't do it, it might be the problem of your picture tube. It is a common problem with modern projection t.v.'s. You can fix this by just replacing the picture tube.
If you can get a working picture tube, of an age old t.v, it would be the best thing you are searching for. Old picture tubes were of superb quality, but the newly produced one's are not so good in quality as well as clarity.
Panasonic... • Answered on Jul 15, 2010
The tuner is soldered on the signal board. You will need to have a 45W soldering iron, some solder wick and of course some solder, (all available from Radio Shack). I sometimes remove the signal board to do this, but you may not have to.
I hope that this helps.
asnowman
Panasonic... • Answered on Jun 23, 2010
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Panasonic... • Answered on Apr 18, 2010
Usually, when a Panasonic projection powers up for a few seconds and then shuts down, it is because one of the convergence IC's is shorted and drawing too much current. This is usually very easy to troubleshoot because the shorted IC causes one of the large reisitors near it to glow red hot just before the set shuts down. The set should be serviced by a qualified tech familiar with Panasonic projection sets.
Panasonic... • Answered on Jun 26, 2008
his is the vertical circuit going bad. you willl need a repairman for this. unless you can solder? a cost of repair might range around 400.00 good luck :)
Panasonic... • Answered on May 02, 2006
Though the 4k Blu-ray player prototype is released in 2015 CES but there isn't that much information for the price and specific launch date we can get from Panasonic. And as I know, the 4K Blu-ray is supposed to come before 2015 Christmas. Too late, huh... So let say the best for now is still watching a good movie with Macgo Blu-ray Player. By the way, it has updated to support 4K.
Panasonic... • Answered 3 days ago
It is a CCD Remote Control Closed Caption Decoder https://www.ebay.ca/itm/124703762639?oid=363341823704 Nothing about manuals https://www.google.com/search?q=Sansui+Orion+076n0dw130+remote+control Buy a remote that is actually made for you Panasonic Model, an exact copy of the original called a facsimile remote. https://www.google.com/search?q=panasonic+tv+remote+control ..
Panasonic... • Answered on May 02, 2021
I have an identical national tc 300 sp 3-in-1 unit. The power input for this set will automatically accept 120-220-240 VOLTS AC. The ac power pins in the 6-pin socket are the two horizontal pins immediately underneath the locating spiggot in the socket.
Panasonic... • Answered on Apr 15, 2021
The power LED blinking ten times is indicative of issues with the voltages on Sub 5V, Main 3.3V, DTV 9V or the Tuner Power and the board in question is the "A-Board". Also, make sure that your units fan and airflow is not inhibited.
Panasonic... • Answered on Mar 13, 2021
Sounds like T'Con board problem. It will be best to contact any service technician to make it sure. i don't think this is a user repairable fault. If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name and model of your set, in its search bar at the right side column, and press enter.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Panasonic... • Answered on Feb 26, 2021
Have you got the tv aerial connected into the dvd?
Panasonic... • Answered on Feb 16, 2021
Panasonic PT-51G53 51" Rear Projection Television Logo
9 questions posted
Top Panasonic Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
sound but no picture
  • Televison & Video
