20 Most Recent Panasonic PT-56WXF95 56" Rear Projection Television Questions & Answers
you will need to install a convergence repair kit for your model. You can get the repair kit called the " WT46807, WS55807, WS65857,WS65907, WS73907 WT46809, WS55809, WS55819, WS65809 and WS65819 Convergence repair kit " which has the parts and the CD with instrucions. Its available at the following link http://tvrepairworld.com/mitsubishi_repair_kits
Panasonic... • Answered on Feb 08, 2013
Power led flashing 3 times, is the error code for convergence failure.
it indicates convergence shut down.
You will need to change both of your convergence ICs they are STK392-110, you can get replacement ICs at the following link with free instalation instructions with pictures so you can do the repair your self. Heres the link.
http://servicemanuals.vstore.ca/index.php/cName/convergence-ics/osCsid/2af56f41a5e336ef2fa7d54dfbea7d57
You can get the service manual from the below link, to know how to service your TV
http://www.tradebit.com/filedetail.php/9186960-panasonic-pt-44lcx65-pt-52lcx65-pt-61lcx65-service Please leave me comment, if you need further assistance RNJ VINODKUMAR
Panasonic... • Answered on Mar 29, 2012
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Panasonic... • Answered on Aug 27, 2011
You need to clean all of the dust and lint out of the ventilation holes in the back and on the sides of the television. The blinking usually means that it is getting hot and dirt and dust are a big part of what causes it.
Unplug it from the wall, press and hold the power button to release the energy from the tv set. Then use canned air and a vaccuum if necessary and clean it out. Then plug it back in and see if it corrects the problem.
Panasonic... • Answered on Apr 27, 2011
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Panasonic... • Answered on Jan 30, 2011
Any colors mis alignments R,G,B.The tv have a problems known as convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced in the tv convergence board to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Panasonic... • Answered on Jul 17, 2010
Did you replace the bulb? clean dust out of fans?
Panasonic... • Answered on Apr 17, 2010
100% Ur 2 STK convergence ICS are still dead.Ur ICS soldering some how,u got the ICS shorted.Or ur ICS not right kind of STK ICS,u replacing in ur convergence board.
Panasonic... • Answered on Apr 07, 2010
hello have you check the glass fuse inside
regards
shaun
Panasonic... • Answered on Jan 17, 2010
56 inch panasonic tv has blue yellow lines running up and down on right side
Panasonic... • Answered on Dec 30, 2009
1.) Ok, you have found your problem---3 blinks is short protection--usually means in this set that one of the two STK-392-110 convergence chips is bad.
2.) I have detailed step by step and start to finish instructions for this repair in this set--I can email them to you if you think you can do the repair yourself. The instructions tell you what things you will need to do it.
3.) If you are not able to do it shop around as most shops TRY to charge 300-400 for this repair. You can buy the pair of chips on Ebay for less than 13 dollars plus shipping.
4.) There is a simple reason this problem happens--the chips are about 2 1/2 inches wide and 1 1/2 inches tall on heat sinks with fins and side by side--they are black and the STK-392-110 number will be printed on them in white---the back of each chip is metal and a white grease is applied to them when they are bolted to the heat sink--after 5 years or longer from the heat the grease dries out and one of the chips cannot move the heat fast enough to stay cool (the grease makes the transfer of heat quick).
5.) There are some blue resistors in front of the chips that are marked 2.2 ohm---if you look and any are white in the middle--they are gone and need to be replaced also(cheap part 2.2 ohm 1 watt resistor) it is a good idea to check all of them.
6.) If you are not able to do the repair shop around in your area--if they say "it has to go to the shop" keep looking---any good tech can do this repair in your home in about a hour--I do hundreds of them here in home for 200-250 total.
7.) If you want the instructions just give me a vote here ( I will email them to you) as I do this here for free.
If you have questions reply to this posting here as I am here to help people
[email protected]
SD TECH
Panasonic... • Answered on Sep 14, 2009
well if its a lcd tv/monitor, that means the lcd has gone bad sometimes that's not the case but i am very sure b/c i work on them all day at the shop, but let me tune you in to somthing well tell every one who comes in our shop eny thing you buy beyond 2003-2004 all of it only last 2 years the only thing I can recommend is macs b/c they build there stuff with better componets, but sorry about that that is a big blow out to know :(
Panasonic... • Answered on Aug 12, 2009
this set should have a built in self diagnostic feature; if you try to turn it on and it does not make it on---watch the power light and count the blinks---for example----3 blinks and a pause and 3 more blinks is the error code---you may have to unplug the set and start fresh--some sets only repeat the error codes 5 times.
Panasonic... • Answered on Aug 07, 2009
I would start by checking the large filter capacitors in the power supply. I can't be sure since I'm not seeing the set, but it sounds like you're describing AC ripple. In a 20-year-old set, some of those electrolytics will be drying out. A few replacements may take care of the trouble for you.
Panasonic... • Answered on Jun 19, 2009
STK-series integrated circuits are amplifier IC's that are most often used in projection TV sets as convergence output amplifiers. When these or other convergence parts fail, the three color images no longer line up correctly on the screen.
Panasonic... • Answered on Jun 17, 2009
Check what format you are in. 4:3 is like a regular tv. Sides will be cut off in this format on a widescreen tv. 16:9 zoomed will cut of top & bottom slightly. You want just regular 16:9. No zoom.
Panasonic... • Answered on Apr 09, 2009
Take off the back and a horizontal cardboard board should slide out toward you. You should be able to see the three tubes and wipe with a soft cloth. The screen should be gently wiped up and down with a soft cotton cloth.
Panasonic... • Answered on Mar 30, 2009
Panasonic PT-56WXF95 56" Rear Projection Television Logo
Popular Tags
38 questions posted
Top Panasonic Televison & Video Experts
Demonic-2011
Demonic-2011
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
power up
  • Televison & Video
