20 Most Recent Panasonic PT-60LC13 60" Rear Projection HDTV Questions & Answers
0answers
Ballast problem
Be the first to answer 8/17/2017 12:18:02 AM • Panasonic... • Posted on Aug 17, 2017Be the first to answer
My TV won't turn on...
Replace the lamp.
9/6/2011 10:05:52 PM • Panasonic... • Answered on Sep 06, 2011
I have a panasonic projection
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
5/6/2011 8:28:19 AM • Panasonic... • Answered on May 06, 2011
Panasonic PT-60LC13 color problems.
dabears85,
You have an optical engine which needs replaced. See my tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine for the procedure involved with replacing the optical engine and also where to get the parts at a good price.
Thanks for using FixYa and for the great rating.
hardrocko
4/28/2011 8:49:14 PM • Panasonic... • Answered on Apr 28, 2011
How to connect my Panasonic TH-42PW6 television with DStv decoder please?
Buy a new television! This old dinosaur appears to be made to connect to a laptop only! No HDMI ports and no Composite Video connections that I can see. You would need an HDMI to Serial Port cable https://www.manualslib.com/manual/648891/Panasonic-Th-42pw6.html#manual https://www.google.com/search?q=Panasonic+tv+th-42pw6+connect+to+DStv ..
11/20/2022 7:21:05 PM • Panasonic... • Answered on Nov 20, 2022
I cannot pair my cordless Panasonic KX-TGEA 40 handset to the base
If you only have the handset, if I remember, you have to unregister it from the base that was paired with it. If you haven't got that base unit, you are stuck. The standard reset is to remove the battery for a couple of hours.
11/20/2022 7:20:40 PM • Panasonic... • Answered on Nov 20, 2022
Panasonic TC-P42C2 Horizontal Lines in Picture
problem could also be inside the display panel.
11/19/2022 4:32:15 PM • Panasonic... • Answered on Nov 19, 2022
Panasonic Viera TH-37LZ85 television. I want to set up my tv but it's in Chinese language?
Question edited for clarity. The language of China is 'Chinese' not 'chaina'. TH or TC? This might be close enough. https://www.google.com/search?q=Panasonic+Viera+TH-37LZ85+manual ..
11/11/2022 1:25:54 AM • Panasonic... • Answered on Nov 11, 2022
My Panasonic 42 plasma turns on then off
Plasma TV sets are impossible to get parts for. The problem that you are describing could be many things but the most likey is failing capacitors in the power supply
11/4/2022 1:34:27 AM • Panasonic... • Answered on Nov 04, 2022
Pt-d5700 Panasonic projector image needs to be adjusted
You could adjust the resolution on your laptop to match the projector, before you start your presentation.
11/2/2022 8:02:17 AM • Panasonic... • Answered on Nov 02, 2022
2answers
The sound stopped working on Panasonic LCD TV model TC-32LX24. I've reset to factory defaults with no luck. Is there a PCB and / or speakers that can be replaced
Hi, You can replace parts but first I would check that your remote volume-down button isn't jammed because this might cause the volume to constantly be low or lower. I would also examine the volume-down button on your tv. Thank you.
10/11/2022 12:09:30 AM • Panasonic... • Answered on Oct 11, 2022
2answers
I have a anko big button remote and I'm trying to pair to a Panasonic plasma modelTH-42px8a I need codes thanks
These are for a Universal Remote. They might work. If not please add the remote manufactuer and model # to comments.
NEC TV 070 130 134 040 056 007 019 024 004 213
NEC VCR 012 023 043 048 039
Good luck,
Techjoel
OR
Turn on your TV.
On your Tune In remote, press TV and release.
Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
Enter the first three-digit TV code for your NEC from the list which follows:
030, 056, 019
These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TVWhy test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
10/6/2022 6:39:33 PM • Panasonic... • Answered on Oct 06, 2022
2answers
My Panasonic DMP-BDT300 has suddenly stopped playing sound most of the time for DVD's? What should I do?
First try this. Does your player have a place to plug in ear phones or head phones? If so use this to see if you can get sound. Then we can work on next step.
10/5/2022 7:50:04 AM • Panasonic... • Answered on Oct 05, 2022
How can I use my GE JC012 Universal Remote to control my Panasonic PV-D4744S ?
003, 054, 055, 062, 070, 148, 149, 170, 171, 374, 381, 437 https://www.directutor.com/content/New_3_digit_codes_GE_Universal_remote_TV
9/29/2022 7:02:02 PM • Panasonic... • Answered on Sep 29, 2022
Panasonic PT-60LC13 60" Rear Projection HDTV Logo
8 questions posted
Top Panasonic Televison & Video Experts
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
  • Televison & Video
