20 Most Recent
Panasonic PV-V4021 S-VHS VCR Questions & Answers
NO PRENDE NECESITO ELMANUSL DE SEVICIO TECNICO
Su manual puede ser encontrado en
http: // www2.panasonic.com/consumer-electronics/support/Video/VCRs/VCRs/model. PV-VS4821
Esto es un manual pdf entonces usted tendrá que descargar al lector de adobe en http: // adobe.com telecargas si usted no lo tiene ya.
12/31/2010 4:02:22 AM •
Panasonic...
Answered
on Dec 31, 2010
We just purchased a Panasonic VCR/TV Universal
The problem with universal remotes is that unless you enter the correct code for that model not all functions will operate. You need to try every Panasonic code in the code book, untill you find one that works the guide function. Otherwise the only real solution is to get the original remote.
8/24/2010 12:49:19 PM •
Panasonic...
Answered
on Aug 24, 2010
Panasonic PV-V4021 VCR.
An analog VCR can only be used the same way as an analog TV. You should be able to set the VCR to the converter boxes output channel ( 3 for example) and then set the VCR to record that channel at the correct times. Then just tune the converter box to the correct channel. Please note that if you try this while you are at home (recording one thing while watching another) you will wind up recording whatever is on the channel you change to.
5/11/2009 8:12:47 PM •
Panasonic...
Answered
on May 11, 2009
Re: Model PV-4523S
You can try cleaning it with a VCR tape cleaner to see if the pinch roller have build up on there. It could be that the motor isnt feeding the tape up against the recording heads properly and may need an adjustment. If you can take the top cover off, you should be to see what the problem is by the way the tape is being inserted into the machine.
9/28/2008 6:02:02 AM •
Panasonic...
Answered
on Sep 28, 2008
Panasonic VCR PV-4652
If the MFD (Multi Function Flourescent Display is not working, check the -27 - 30 Volt (minus 27V to minus 30V) supply line. The fuse or a fuse resistor (around .5ohms 1/8W ) will be blown.
Also, it is possible that the 3V AC heater supply line is disconnected at some point.
Check that also.
7/20/2008 7:12:09 AM •
Panasonic...
Answered
on Jul 20, 2008
Toshiba M-782
If pictures are rolling during normal playback, just check one thing first. Open the Cassette flap and see the condition of the tape. Is it chewed and stretched at the bottom? If yes, the problem is a worn Capstan / Pinch roller in the VCR. It is cheweing up the lower edge of the tape, and therefore the VCR is not able to process the 'Control Track.
All you need to do is replace the Capstan / Pinch roller.It is a big (approximately 1 inch high by 1/2 inch wide Black Rubber roller inside the VCR. REPLACE. Problem will be solved.
7/20/2008 7:09:01 AM •
Panasonic...
Answered
on Jul 20, 2008
Picture is jittery and voice is garbled with noise in background
I had the same problem recently with a Panasonic PV - V4521 which has worked for years for me. I tried everything including cleaning the heads with Q-Tips and pure alcohol. Nothing improved. I tried tape head cleaners. Nothing. So finally one day, as I was unscrewing the cables, this VCR fell down onto the bottom of my foot and drew blood. Now remember, I had been trying to fix this thing for at least 10 days.
So, I dragged it up and pounded the top of the VCR until the top caved in. Then, I opened my front door and tossed it so hard against the floor of my patio that pieces went flying everywhere. I gathered up the pieces and the twisted VCR, put it in a box, and tosses it real hard into the dumpster. It's fixed. I have no more problem with it.
7/4/2008 1:02:59 PM •
Panasonic...
Answered
on Jul 04, 2008
Fisher vhs
Sorry, you need the remote. There are sites that sell remotes.
Try partstore.com
1/2/2008 4:47:44 AM •
Panasonic...
Answered
on Jan 02, 2008
Panasonic pv-v4021 VCR
Actually George, You should read the supplied Operations manual. In that you will find a chapter for using the Remote as a Universal remote, and a list of codes will be give. Check out the code for Misubishi TVs and feed that.
9/26/2007 4:51:49 AM •
Panasonic...
Answered
on Sep 26, 2007
Guide Rollers Won't Engage
hi
sorry
cant help tou more then before
it cant be solved in remote
look for torn straps
broken wheels
look from where the noise is coming from
it will give you a hint whats the problem
DONT KNOW?
take it to a technician
good luck
2/26/2006 1:53:08 PM •
Panasonic...
Answered
on Feb 26, 2006
Cassette loading process won't complete
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation.
If you're NOT still under warrantee you should at least open the VCR and Check all the belts above and below the deck. Belts can appear to be firm but if they do not return immediately to their relaxed length when you stretch them 25%, they will need to be replaced.
With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see:
1. The video head drum begins to spin.
2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks.
3. The pinch roller moves into position and presses the tape against the capstan.
4. The tape begins to move and is wound up by the takeup reel.
5. The picture and sound appear on the TV.
With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted.
This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head.
With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.)
Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette.
In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY.
12/30/2005 2:49:07 PM •
Panasonic...
Answered
on Dec 30, 2005
Panasonic hds700tds playing audio no videos
- Check the Input Source: Make sure you have selected the correct input source on your TV for the device you are using. Use the remote control to cycle through the input options until you find the one connected to your video source.
- Check Video Connections: Ensure that all video cables (such as HDMI, component, or composite cables) are securely connected between your TV and the device you are trying to watch content from. A loose or faulty cable connection could result in a loss of video signal.
- Restart the TV and Video Source: Try restarting both your TV and the device you are trying to watch content from. Power off both devices, wait a few moments, and then power them back on. This can sometimes resolve temporary glitches or issues with the video signal.
- Check for Software Updates: Make sure your TV's firmware is up-to-date. Sometimes software updates can resolve compatibility issues or bugs that may be affecting video playback. Check the settings menu on your TV for an option to update the firmware, or visit the manufacturer's website for instructions on how to do so.
- Reset Video Settings: If you've made any changes to your TV's video settings, such as resolution or picture mode, try resetting them to their default values. This can sometimes resolve issues with video playback.
- Try a Different Device: If possible, try connecting a different device (such as a DVD player or gaming console) to your TV to see if the issue persists. This can help determine whether the problem lies with the TV itself or with the original device you were using.
- Contact Panasonic Support: If none of the above steps resolve the issue, it's possible there may be a hardware problem with your TV. In this case, you may need to contact Panasonic customer support for further assistance or to schedule a repair.
- Hope this helps
4/9/2024 11:43:10 PM •
Panasonic...
Answered
on Apr 09, 2024
I have a Panasonic 50-in flat screen TV a storm came by and knocked out my TV and my Yukon no breaker was off so did it come through the antenna please help
- Check the Power Cord: Ensure that the power cord is securely plugged into both the TV and the power outlet. Make sure there are no visible signs of damage to the power cord or the plug.
- Inspect the Power Outlet: Try plugging another electronic device (such as a lamp or a phone charger) into the same outlet to verify if it is functioning properly. If other devices work fine, then the issue is likely not with the power outlet.
- Check for Tripped Circuit Breakers: Check your circuit breaker or fuse box to see if a circuit breaker has been tripped or a fuse blown. If so, reset the circuit breaker or replace the fuse and try plugging in your TV again.
- Test with Different Power Source: If possible, try plugging your TV into a different power source altogether, such as a different room or building. This will help determine if the issue is specific to the power source you were previously using.
- Contact Panasonic Support: If none of the above steps resolve the issue and your TV still does not power on, it's likely that there is a hardware problem with the TV itself. In this case, you may need to contact Panasonic customer support for further assistance or to arrange for repairs. Be sure to provide them with details of the troubleshooting steps you've already taken.
Hope this helps
4/9/2024 7:56:16 PM •
Panasonic...
Answered
on Apr 09, 2024
