20 Most Recent Panasonic PV-V4624S VCR Questions & Answers
Try these codes, If they don't work there will be instructions for a Power Scan as well this should resolve this!
Codes: 734,856,855,868,869,870,871,872,873,882,813,765,840,841,639,699,663,714,715,716.
Power Scan:
1.) Press and hold the correct VCR button (about six seconds) until all mode button backlights come on, then release.
2.) Press 222 pound (#) then record three times.
3.) With the desired equipment on, press and hold the VCR/DVD button until all mode button backlights illuminate (about 3 seconds), then release.
4.) Press and release the Power button.
5.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
6.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
To verify the code works try several different functions for that equipment.
Daniel Busa
DISH Network Customer Service
Panasonic... | Answered on Feb 23, 2011
The issue is most likely the plastic gears inside, they would need to be lubricated to get the vcr to function properly again.
make sure all the gears move properly (while having the top cover of the vcr off, make sure that all the gears move without getting stuck or similar, this can be easily spotted when you have it apart, do not touch the powersupply area or anything else while the machine is plugged in)
it would be best to do the maintenanced unplugged but the gears might be difficult to move without power in the machine, if possible don't plug in while the cover is open.
the issue can also be a number of things that you should be able to spot once you have the vcr apart.
If you have no experience at all, it might be best to take the vcr to a local repairer.
Panasonic... | Answered on Feb 09, 2010
SET YOUR TO RF LEVEL " LOW" OR YOUR CABLE CONNECTION IS WRONG CHECK IT.IF THE PROBLEM REMAINS, CHECK IT ON STANDARD DEFINITION TV FOR RECORDING.IF THE PROGRAM RECORDS OK THEN IT ID NOT COMPITIBLE FOR DIGITAL SIGNALS. BUT IF NO RECORDINGS PERFORM CHECK THE VIDEO HEAD CLOGGINGS OR MAY BE MAIN "IC" PROBLEM.
Panasonic... | Answered on Feb 23, 2009
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site either in Web View, on a mobile; or by a desktop PC. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Panasonic... | Answered 3 days ago
The cable that is compatible with both items. You do not say so I cannot advise.
Panasonic... | Answered on May 23, 2020
If you do not replace the faulty SS and SN boards then it will take out your power board as soon as you switch it on!
Replace all three.
Panasonic... | Answered on May 21, 2020
https://codesforuniversalremotes.com/panasonic-dvd-player-remote-control-codes/
How To Program A Samsung Remote To A DVD Player
  1. 1 - Turn your DVD player off.
  2. 2 - Press the Mode button on your remote to switch the remote to DVD mode. ...
  3. 3 - Press the Set button on the remote control.
  4. 4 - Enter the three digit DVD player code listed in your TV's user manual. ...
  5. 5 - Press the Power button on the remote control.
https://www.directutor.com/content/how-program-samsung-remote-dvd-player
Panasonic... | Answered on May 19, 2020
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
View the site by desktop or webview on mobile devices to see the "search box". Type in the brand name of your set in search box; to get gathered the related posts.
Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Panasonic... | Answered on May 18, 2020
Generally I advise against the self repair of television sets as it always ends in tears and frustration.
https://www.ifixit.com/Answers/View/385126/light+flashes+10+times
SOLVED: The television will not turn on, power light blinks 10 ...
www.ifixit.com > Answers > View > The+television+will+not+turn+on...
Jun 22, 2011 - This is what I get from the Panasonic 9th generation plasma: If any of the SUB or MAIN voltages that are highlighted on the DG Board is missing ... SOLVED: light flashes 10 times - PANASONIC TH ...
Mar. 22, 2017
red light flashes 10 or 11 times doesn't come back on ...
Oct. 5, 2013
Panasonic Viera blinking 10 times and do not turn on ...
Oct. 6, 2017
SOLVED: Panasonic TC-P50S1 10 blinks? - Panasonic ...
Oct. 29, 2016
More results from www.ifixit.com
I have a Panasonic TC-P42U2 plasma tv, and I am getting a ...
www.justanswer.com > ... > TV Problems > Plasma TV Problems
Dec 13, 2013 - The 10 blink code is the most general code that Panasonic uses, and it is only a starting point as to where to begin troubleshooting. To narrow it ...
TC-P42U2 panasonic 42" plasma, 10 blinks - Badcaps Forums
www.badcaps.net > forum > showthread
Oct 16, 2014 - To cut to the chase this set has the 10 blink code so I'm hoping that maybe I'll be able to fix it since boards seem to be scarce but this tv is only 4 ...
Panasonic... | Answered on May 16, 2020
Did you let the board dry out after it's journey by air and van to your home? They get damp from condensation and temperature changes.
This is my standard response to home television repair!
This explains why, and why you can't diagnose television problems on an online forum. The television sections are really only for help with manuals and remote codes.
Here are similar questions that we see often.
Question:
I've replaced everything in my television because it previously had a black screen with no lighting. Now it doesn't turn on at all and all I have is audio. What could be the cause ? Or
Turns on and sound works fine, but the picture is distorted (solarized? polarized? not sure what the term is) I replaced the main board, but that didn't fix it.
Or
I have an LG 55LM6200-UE with a dim lower-left. I just replaced both LED strips with no resolution. There is no physical obstruction visible, so this has to be a cable or board problem, right?
So your television stops working properly and you think it must be easy to fix, because you can buy boards on eBay, and you can watch YouTube videos. So you make a decision, you buy a board and you fit it, but the television still doesn't work as it should! This is a classic case of the 'let's try replacing this' method of television repair and illustrates why it is a bad idea. It doesn't work for a number of reasons. To correctly diagnose issues, you need to know every board, what it does and every component on the board. You need to know which part has failed, replace the component, or replace the board. The parts you purchased off eBay were probably out of scrapped sets and not tested. The part you put in was dead when you put it in, so you just moved on to another guess at what might be the cause and replace a board that is fine. And so it goes on, you change all the boards and it still doesn't work. Did you notice the large print that says 'NO Refunds, NO Returns'. This is to stop you sending your old one back and saying it didn't work, but the unscrupulous sellers use it as an excuse to get money for selling items that may, or may not work! The course to be a television engineer is 2 years full time education, take it to someone that knows how to diagnose and fix. It is by far the cheapest option. The part that failed might be a 20 cents fuse diode hard soldered to a board. They will charge you $5 in parts and a couple of hours labour. It's not the fix you want to hear, but it is the best advice.
Andrew - Fixya Moderator
Panasonic... | Answered on May 11, 2020
IPTV Free trial and IPTV Download guide: https://buyiviewhdiptv.blogspot.com/2019/03/iview-hd-iptv-free-trial-and-apk.html
I hope my answer will help you.
Panasonic... | Answered on May 08, 2020
Hold the "Power" button on the front of the player. After a few seconds, the display says "Reset"; let go of the button. When the "ON/Standby" button turns on, press the "Power" button to turn the player on.
https://www.techwalla.com/articles/how-to-reset-a-blu-ray-player-that-is-frozen
https://www.youtube.com/watch?v=TB6otbYFKRc
Panasonic... | Answered on May 07, 2020
Easy enough to replace, just 4 screw and a few plugs. however read this cautionary tale I wrote.
Yes, that never fixes the problem. This explains why, and why you can't diagnose television problems on an online forum. The television sections are really only for help with manuals and remote codes.
Question:
Or
https://www.panasonic.com/caribbean/support.html
http://www.csportal.panasonic-la.com/sys/cschat.html
Panasonic... | Answered on May 06, 2020
Panasonic PV-V4624S VCR Logo
6 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
need manufacture code
  • Televison & Video
