20 Most Recent Panasonic SC-DK10 System Questions & Answers
How do I unlock the panasonic sc dk 10
From what I can see the only way to do it is by fitting a special chip. A website is offering a modification kit for sale. JVB Digital Codefree Panasonic SA DK10 DVD modification kit
9/20/2018 11:54:26 PM • Panasonic... • Answered on Sep 20, 2018
2answers
Panasonic SA-PM39D malfunctioning with F61.
please clarify exactly what is happening, fault codes are only supplied to factory approved repair center, we have no direct access to these codes.
3/7/2017 2:29:10 PM • Panasonic... • Answered on Mar 07, 2017
0answers
2answers
F61
F61 tells you its a power source problem
6/17/2011 9:00:34 AM • Panasonic... • Answered on Jun 17, 2011
System wont accept cd or DVD - error message is
cd mech loding problem checked panasonic service locator:
http://www.pstc.panasonic.com/WhereTo/FindServicer.asp?ValidJS=1&Pass=1
6/27/2010 8:16:16 AM • Panasonic... • Answered on Jun 27, 2010
Panasonic SA DK10 starts reading discs, gets to 00 and then stops
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case this don't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
5/12/2010 11:45:22 AM • Panasonic... • Answered on May 12, 2010
F61
deffective power supply section or audio amplifier IC
(RSN311)
4/22/2010 7:00:08 AM • Panasonic... • Answered on Apr 22, 2010
When i put cd or dvd start reading and stop and
deffective spindle motor
4/22/2010 6:57:53 AM • Panasonic... • Answered on Apr 22, 2010
When insert disc that time showing no disc
1. Bad disk format
2. Disk reader head is unrefined
3. Panasonic might not read this kind of disk.
4. Electrical failure
2/24/2010 10:38:17 AM • Panasonic... • Answered on Feb 24, 2010
I plug mine in then press the on button it dims
try just powering up the system without any components or speakers connected and see if it still happens.
Good Luck
1/17/2010 1:59:45 AM • Panasonic... • Answered on Jan 17, 2010
Dvd stereo system SA-DK10 does not read cd's and dvd's
I took mine to Radio Shake and they replaced the mechanism for the reader. It was a total of 150.00 but it was worth it. I have to give it to them and they had to send it out to see what was wrong with it. I have used it two years later and it still works good. On occasion when I play about three to five dvds it will stop. After I let it cool down it starts working again. I am selling mine after 8 years of having it because my girl friend bought me a blue-ray theater system for christmas. Other then that it is a great product. if you need anything else let me know. [email protected]
12/29/2009 12:07:22 AM • Panasonic... • Answered on Dec 29, 2009
How can I burn mp3 CD-R ?
MP3 pro?! Have you tried using a 3rd party writer like roxio and just chose data disc option, or import them into a conversion software even import into itunes (insuring mp3 is your selected format) and write the mp3 files created.
6/26/2009 3:50:38 PM • Panasonic... • Answered on Jun 26, 2009
2answers
NO disc
The same happened to me recently, you need to go to your electronic store and purchase a CD/DVD laser lens cleaner, put it in run it problem solved
6/21/2009 12:08:32 PM • Panasonic... • Answered on Jun 21, 2009
Surround Sound
You can run your sound from the TV or cable box (if those devices have that capability), but NO you can't run video into the SA-dk10. DVD is the only video output.
1/25/2009 7:08:36 PM • Panasonic... • Answered on Jan 25, 2009
3answers
DVD trays out - Panasonic SA-PM39D
there are very tricky mechanical devices that detect when the trays are closed and in what position they are in
A gear or mechanical piece is not in correct order or not functioning properly and will need intense studying to determine which position they all should be in at door closed , laser mech. position , standby position
can you upload a photo of the inside of the cd mechanism?
10/28/2008 3:13:41 PM • Panasonic... • Answered on Oct 28, 2008
How to rebuild, step by step, CD Changer Mechanism for Panasonic SA-AK20?
The nearest you will get is the service manual. Dowmload the service manual and follow the dissasambly and reassambly instructions to the letter, otherwise it will not work correctly and the timing will be out. https://elektrotanya.com/panasonic_sa-ak20.pdf/download.html
4/1/2024 8:34:15 PM • Panasonic Audio... • Answered on Apr 01, 2024
Panasonic SC-DK10 System Logo
22 questions posted
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Audio Players & Recorders
Most Popular Question
f61
  • Audio Players & Recorders
