20 Most Recent
Panasonic SC-HT820V System Questions & Answers
Doesn't respond to any commands
condensation has formed wait for 1 to 2 hours to evaporate.
the unit can not play discs other than who listed in operation instruction.
2/3/2009 12:15:38 AM •
Panasonic...
Answered
on Feb 03, 2009
NO SOUND
Try ti see if all the cables are connected properly and that the speakers havent been placed in a wet or damp environment, other than that it could be an inner speaker wire problem, one of the wires may have come loose.
11/24/2007 3:36:12 PM •
Panasonic...
Answered
on Nov 24, 2007
No sound for regular tv channels
You may need to connect an AV cable from the Audio out L & R a the back of your tv..into your Audio L&R input sockets of your hometheatre unit. OR you may need to setup the TV channels in your home theatre unit using its remote control to do so, with your TV set to AV1 or AV2 or AV3 depending on how you have the cables connected.
Sometimes its just amatter of disconnecting all cables in your particular installation ....going to bed...then restarting the cable connection proceedure shown in your manual with a refreshed mind.....its so easy to make cable connection errors when one is excited about getting the desired entertainment hit by having it all running ok eh? Hope this helps - hattonhall
9/8/2007 2:51:28 PM •
Panasonic...
Answered
on Sep 08, 2007
I have a panasonic sa vk880 and it wont give sound outputs, when i click on subwoofer button or surrounded enhancer it says error, please help
Try disconnecting all of the speakers except the left and right main speakers. If it works, check the wiring at the back of each speaker to make sure there aren't any shorts between the terminals. Better yet, just inspect the terminals both at the audio unit and the backs of the speakers. Stray strands of wire reaching across to the other terminal or exposed wire on the other side are a common problem.
If you have that all cleaned up and still have the error, you may have shorted transistors in the output amp of one of the channels, very likely the subwoofer. This may be caused by shorted speaker wiring, or the amp may have failed on its own. In either case, you would have to replace both of the output transistors for that channel (they may be built into a power amp module, in which case the module must be replaced). This requires soldering skill, and the knowledge to identify the transistors and check them with an ohmmeter. Most of the time, it's a basic job for any skilled electronic technician. (I did run into one model that would have required two days of disassembly labor just to get at the failed transistors - I told the customer that wasn't designed for service and he would be better off buying something different to replace it.)
Panasonic SA AKX71 controller
Original CD Stereo System comes with remote control and that does not need to connect. Moreover, buttons and switches are also given for manual use. If you want to use universal remote control, please specify make and model.
Panasonic DVD CD and vidio CD made in 2002
If your Panasonic DVD/CD player is not reading CDs and is making a grinding noise, there could be several issues at play. Keep in mind that specific troubleshooting steps may vary based on the exact model of your DVD/CD player. However, here are some general suggestions:
- Cleaning the Optical Lens: Over time, the optical lens inside the DVD/CD player can accumulate dust and debris, leading to reading issues. You can try using a CD/DVD lens cleaning kit to clean the lens. Follow the instructions provided with the cleaning kit.
- Check the Disc: Ensure that the discs you are using are clean and free from scratches. Even new CDs can have manufacturing defects. Try using different CDs to see if the issue persists.
- Inspect the Loading Mechanism: The grinding noise you're hearing could be related to a problem with the loading mechanism. Open the disc tray and visually inspect for any obstructions or foreign objects that may be hindering the movement of the tray.
- Reset the Player: Turn off the DVD/CD player and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This can sometimes resolve temporary issues.
- Firmware Update: Check if there are any firmware updates available for your DVD/CD player. Visit the Panasonic website, enter your model number, and look for firmware updates and instructions on how to perform them.
- Professional Inspection: If the issue persists after trying the above steps, it may be necessary to seek professional assistance. There could be a mechanical problem with the internal components of the player that requires specialized attention.
If you are unable to find the exact manual for your specific model online, you may want to contact Panasonic customer support directly. They can provide you with model-specific advice and may have access to manuals or troubleshooting guides for your particular DVD/CD player.
