20 Most Recent
Panasonic SC-HT830V System Questions & Answers
Where can I get a vepv0037a display board
It may not be needed. Try shorting across this fuse protector IP1280 (looks like a resistor)
on the
power board. See more detailed solution I posted in this forum for a
similar
question.
4/19/2014 3:07:06 PM •
Panasonic...
Answered
on Apr 19, 2014
The display on the front of the dvd player is not working
I finally got some time to run this one down. I first took the "easy" solution and just ordered a new display and replaced it. No luck.
I traced the problem to the grid voltage going to the fluorescent display, it is a vacuum tube and requires grid heater voltage. The circuit goes through a switching transistor on the display board (board not available) through the DVD board (circuit wiring only) through a diode and fuse protector on the power board (also not available) to a transformer. The fuse protector was open, but the transformer was not putting out the right voltage. I replaced the transformer and jumpered the fuse protector and that solved the problem. I will need to put something in there for circuit protection as it may be a current limiting fuse protector but the part was not even in the parts.com parts list.
Cause: Temperature and/or voltage surge caused transformer and fuse protector to fail. Transformer rang OK, only display voltage affected.
My Solution: Replace transformer T1150 and Fuse Protector IP1280.
Possible cause of others who replaced the display board: Voltage surge may have taken out switching transistor Q7001 on display board. This transistor is turned on by QR7201 & QR7201 in a Darlington pair when PowerSave goes low. I did not under stand this function since the display is never completely off. It may dim it but I don't recall the display dimming. It may be non function on this model so jumpering E-C on Q7001 might solve the problem for others.
Parts replaced:
T1150 Transformer G4D2A0000216
IP1280 Fuse Protector K5G252AA0003
John
6/22/2013 10:03:08 PM •
Panasonic...
Answered
on Jun 22, 2013
No Display
Could be an easy fix. Try shorting across this fuse protector IP1280 (looks like a resistor)
on the
similar
question.
2/19/2012 5:21:08 AM •
Panasonic...
Answered
on Feb 19, 2012
I have a Panasonic DVD/VHS
clean the heads of the VHS machine,, if they are clean,, check the video wire connections( the yellow one)
5/31/2011 4:12:12 PM •
Panasonic...
Answered
on May 31, 2011
No light in front panel
You may be able to fix it yourself. Search this forum or my profile for a more detailed solution to the same question worded differently, it is the one will a lot of photos. Try shorting across this fuse protector IP1280 (looks like a resistor)
on the
similar
question.
6/6/2010 4:57:52 AM •
Panasonic...
Answered
on Jun 06, 2010
Same issue!!!
Here is an easy fix that may work. Try shorting across this fuse protector IP1280 (looks like a resistor)
on the
similar
question.
6/6/2010 4:56:12 AM •
Panasonic...
Answered
on Jun 06, 2010
ANY IDEA WHERE I CAN GET A VEPV0037A PART FOR MY
May be the grid power to the display. Try shorting across this fuse protector IP1280 (looks like a resistor)
on the
similar
question.
6/6/2010 4:55:28 AM •
Panasonic...
Answered
on Jun 06, 2010
VEPV0037A display board
Try this. Try shorting across this fuse protector IP1280 (looks like a resistor)
on the
similar
question.
6/6/2010 4:52:25 AM •
Panasonic...
Answered
on Jun 06, 2010
