20 Most Recent Campbell Hausfeld Husky Gravity Feed HVLP Spray Gun, HDS79000AV Questions & Answers
2answers
Can i use this spay gun to spray down bed lineing
Not likely
The tip will be too small for
bed liner material
Check the specs on the product
you want to use
10/4/2014 6:02:16 AM • Campbell... • Answered on Oct 04, 2014
0answers
Air bubbling up in cup
it means the air holes in the nozzle are blocked the air couldn't get out in the front so instead it went back to the cup makes it bubble
9/17/2011 8:59:58 AM • Campbell... • Answered on Sep 17, 2011
We are having trouble getting
when you pull the trigger can u see the needle moving backward? if so, then it's either the paint is too thick compare to the nozzle size or the passage for paint is blocked. try to take the nozzle, needle and the cup off and give it a good clean!
9/8/2011 10:21:24 AM • Campbell... • Answered on Sep 08, 2011
0answers
Campbell Hausfeld air gun has air coming from the nose tip and no nails
If air is coming out from the nose tip but the nailer is not firing any nails, it could indicate a problem with the driver blade or piston assembly. Check if the driver blade moves freely and is not damaged. Make sure the piston assembly is properly aligned and lubricated. Also, check the nail magazine to ensure that it is properly loaded and the nails are the correct size for the nailer. If the problem persists, it may be necessary to take the nailer to a professional for repair.
2/14/2023 2:59:32 AM • Campbell... • Answered on Feb 14, 2023
Where can I get replacement oil-less piston rings or the sheet material to cut my own?
You may be able to find a seal kit at an auto parts store, I have had good luck with them.
11/5/2022 1:10:17 PM • Campbell... • Answered on Nov 05, 2022
Need to know start cap specs for c1071080vmsa campbell air compressor
Kranson 3 Nov 03, 2022 I'm late to the party, BUT... There's 2 ea of both start and run capacitors in this compressor... Start: PN- 351052-53, 815-970 MFD, 165VAC Run: PN- 175863-30, 30MFD, 370VAC --------------------------------------------------------------------------- The section ^^ UP THERE ^^ is for asking the OP further information before committing to an answer down here. The question is now marked SOLVED and will show in Search. Thanks
11/3/2022 5:10:21 PM • Campbell... • Answered on Nov 03, 2022
How to stop Campbell Hausfeld FP209402 from smoking?
sounds like your compressor is finished it is not economically feasible repairable. $90.00 for a new one
10/2/2022 6:21:28 PM • Campbell... • Answered on Oct 02, 2022
What size staples does a campbell hausfeld tl1012 stapler use
It uses 5/16 staples
11/10/2021 12:55:53 PM • Campbell... • Answered on Nov 10, 2021
Campbell hausfeld wont build pressure
The most probable are Leak in air lines, bad valves, bad piston rings or o rings., bad check valve on tank, leaking unloader valve. Tou can google your model number and there will be more info.
10/30/2021 3:21:28 PM • Campbell... • Answered on Oct 30, 2021
Where to bye jda 22ukc battery charger 120 v for campbell hausfeld
https://poweradapter.co/jda22u-ac-adapter-22vdc-500ma-power-glide-charger-power-supply-p-666.html
10/30/2021 12:46:24 AM • Campbell... • Answered on Oct 30, 2021
Model FP220700 (2003). What tools do I need to remove housing?
junk it
9/16/2021 1:03:30 AM • Campbell... • Answered on Sep 16, 2021
Hello Have a 6gallon capbell hausfeld. Motor has 2 capacitors on it.Will not start it just humms.What might be the problem?
After power is off and you have shorted across the capacitor terminals, check to make sure the spade connectors are not loose. The disc on top of the capacitors should not be bulged out. It is is, that capacitor is bad. The other possibility is that the centrifugal start switch in the motor is stuck in the Run position.
2/9/2021 4:01:46 PM • Campbell... • Answered on Feb 09, 2021
Parts for my Campbell hausfeld nailer/Stapler Model number SB504000 Or SB52000
fixya does not source Campbell Hausfeld parts. Try contacting CH directly.
11/15/2020 4:37:11 PM • Campbell... • Answered on Nov 15, 2020
I need the torque value for a Campbell Hausfeld air compressor model no. Vt558704
HAVE NEVER SEEN ANY ANYPLACE
11/8/2020 9:51:47 AM • Campbell... • Answered on Nov 08, 2020
2answers
Why does my campbell hausfeld 80 gallon 2 phase air compressor start to bog down at 90 psi
There is many reason for this simptome , could be running capacitor ,, Pressure switch dirty or it going bad,, Or ,If you meen lick choking and conteniu going could be also your check valve ,,, If you can post a video I will help you better , I need to hear what it doing ,
9/8/2019 9:33:07 AM • Campbell... • Answered on Sep 08, 2019
Campbell hausfeld fp200201av starts up fine but stalls when i use air and it needs to refill the tank. What should i look for?
Try the start capacitor on the motor and the centrifugal switch inside the end cover of the motor.
4/27/2019 4:54:33 AM • Campbell... • Answered on Apr 27, 2019
Campbell Hausfeld Husky Gravity Feed HVLP Spray Gun, HDS79000AV Logo
Popular Tags
10 questions posted
Top Campbell Hausfeld Air Tools & Compressors Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
ZJ Limited
ZJ Limited
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Campbell Hausfeld Air Tools & Compressors
Most Popular Question
use spay gun spray down bed lineing
  • Air Tools & Compressors
