20 Most Recent
Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX AMD Motherboard Questions & Answers
Biostar n68s3 is dead
many are, this old , coin cell dead
and 20 other things
wana do 20 tests? and 20 questions.???
power on light dead.
fans dead
hdd hear not to spin sound.
monitor is dead/ all are if older than 2010, CCFL lamp tubes dead.
just failed now or bought it dead???? no history told and matters
No Beeps, Post, Nothing.
make sure the p4 power connector is plugged in. (4 wire yellow and black wires) plugs in near cpu. Remove and reinsert memory modules. That is were I would start.
How to connect panel 1 of n68s3+
PANEL1: Front Panel Header for Biostar N68S3+ from http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=506#dlThis
16-pin connector includes Power-on, Reset, HDD LED, Power LED, and
speaker connection. It allows user to connect the PC case's front panel
switch functions. Pin #1 has a black square on the motherboard and the
pins are oriented from 1-8, left to right, bottom row and 9-16, left to
right, top row. You will notice that there is no #11 pin. pin #'s1-2-3-4 Speaker (1+, 4-)5-6 hard drive LED (5+, 6-)7-8 reset switch (7-, 8+)9-10-11 N/A (not used)12-13-14 power LED (12+, 14-) ** only if power wire is 3 port connector **13-14 power LED (13+, 14-) ** only if power wire is 2 port connector **15-16 power button (15+, 16-)Did this solve your problem?
Windows install doesnt read sata drive but BIOS does
change the hdd's data cable it could be helpful ,,, sometimes when the hdd have a bad sectors it becomes not accessible there a good program to repair bad sectors called ( hdd regenerator ) after you use it ... you'll be able to format your hdd ...
Was told there should be
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
COMPUTER ON FOR A COUPLE
to shutdown or fail to detect your hard drive
Test the leads that attach
to your ((hard drive from the motherboard)) or replace all the leads that
attach to your hard drive including electrical extensions + IDE,SATA and the
ones that attach from your ((motherboard to hard drive))
could be faulty a computer needs its connections needs its connections continue
its cycle and to have an end so any faulty leads will end up with a computer
error
hope this helps
Tengo problemas con la Biostar
Yo dir?a de probar la micro y luego la memoria en distintas placas madres, para descartarlas. Yo me volcar?a a pensar que es cosa de la placa madre.
Tambien puede haber una posibilidad de que el problema este en la copia de windows (qu? version es?) Puedes probar con otra versi?n de windows o con un live cd con linux.
Biostar i945cm7b
best is noobs avoiding UEFI
and 945 is 2005 tech, not modern UEFI bios .at all
but do ask maker this.
but 945 ended there.
6/6/2022 1:34:56 PM •
Biostar...
Answered
on Jun 06, 2022
Mainboard Vestel 14MB02-03 no power
posted to computer repair help, PCwhat computer is this, not toldVestel 14MB02-03 (mobo labels useless)Vestel made this mobo under contract to an OEM PC maker,. like BIOSTAR? or who? not told really.Vestel does not sell PCs ! google shows no hits (zero). posted wrong PC model?ahhhhh coded words off mobo white painted silk screenssureI see one hit on that number alone and shows LAPTOP PC MOBOclearlyok , why post mobo models. and not real maker of PC laptop model, did you somehow lose the laptop casings.??>???????????odd odd post this is, like that. we fix PC by makers name and real models. not mobo codes. sorrythe model is on the bottom tab on laptops oldor in bios screen 1 toldnow and answer for laptops old. 1: big battery dead and worse shorted making PC dead, remove it run on AC power pack only,see it works.2: coin cell dead, sure it is that old replace it.3: any of up to 20 other modules inside shorted out.4: stuck in sleep mode dead, push power button for 10 seconds and release, runs now?5: LCD CCFL back lamps dead, use a flash light pointed to screen to see data turned on, if seen the CCFL is dead.(aka, background light tubes)
6/6/2022 12:42:55 PM •
Biostar...
Answered
on Jun 06, 2022
Audio Adapter ESS Technology ES1938/ES1941/ES1946 Solo-1(E) AudioDrive for windos 7
no PC told no OS told but it was for XPbiostar ended support. windows 7 is oct 2009 OSthe old XP driver is here.https://www.majorgeeks.com/files/details/ess_sound_card_es1938es1946_(es1969).html2006 sound cards. it is PCI not PCI-expressso is useless on all modern PC>but since you imply it fits to a PC the PC is a relic and not told the chip sets on the card are not supported by them maker of the chips so is double dead.(product line not maker)https://www.esstech.com/as you see no es1938 era support.if you google things that do not exist the prize is a nasty virus, here is a short test for w7 just for you.the waybackmachine.com shows https://www.esstech.com/going dead (for legace) 2007so dead 2 years before w7 was released.XP lasthttps://web.archive.org/web/20070202023729mp_/http://www.esstech.com/techsupp/drivers.shtmas you can see the FTP links to the drivers are dead.for ever and ever.now to w7 year, 2009 dec, 2 months from w7 releasetiming is everything , no?the endhttps://web.archive.org/web/20091213143106/https://www.esstech.com/they ended all legacy then./ that means so did biostar. with no base drivers it ends.RIP ESS legacy.
5/17/2022 7:12:49 PM •
Biostar...
Answered
on May 17, 2022
MP6PB M2 DRIVER
asked 1000 times learn to search here? OR
1001
GOOGLE BIOSTAR HOME
GO THERE
5/17/2022 6:39:51 PM •
Biostar...
Answered
on May 17, 2022
K8m800 am2 la motherboard schematics
there are no schematics ever.
yes mobo connectors all and more.
in the manual
learn to google first.
google Biostar home
this gets you the correct web site for you country,
then RTM.
5/17/2022 6:38:49 PM •
Biostar...
Answered
on May 17, 2022
Manual ms-7050 ver:2.0
GOOGLE BIOSTAR HOME
GO TO your countries support paGE THERE.
LEARN GO GOOGLE
FOR MANUALS OR DRIVES AND all
5/17/2022 6:25:59 PM •
Biostar...
Answered
on May 17, 2022
