20 Most Recent True GDM-7 Beverage Cooler Questions & Answers
Doubt if it is a gas problem. Sounds more like a thermostat issue. Rather surprised that the evap coil is not frosting or freezing up. System may have a defrost cycle or and off cycle defrost long enough to keep it clear. Try to pay attention to the cycling of the compressor to see if it is excessively running long. Thermostat may be available from Restaurant Parts and More. 1-888-814-1110. Talk to Matt or Bryan as they are the most experienced.
True GDM-7... | Answered on Jan 16, 2018
On this video You will find how to access condenser motor on true refrigerator.
True GDM-7... | Answered on Jun 27, 2015
A trained refrigeration technician can charge all units
Are you referring to the compressor not shutting off down below or the evaporator fan inside the cooling area not shutting off? Evaporator fan always runs the compressor is controlled by the thermostat you could have a bad thermostat if the compressor never shuts off.
Did you fit a manufacturers original or an after market model?
When the thermostat was replaced was it fitted to exactly where the original thermostat was fitted?
These things are tempremental and must be fitted just so.
True GDM-7... | Answered on Apr 01, 2011
Possible that the thermostat control is not reacting to the setting.
so you must check if there is any break or replace the unit.
True GDM-7... | Answered on Sep 13, 2010
You need to turn the thermostat up ....the drinks are frezzing and that explodes them...
heatman101
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
True GDM-7... | Answered on Aug 11, 2010
You should clean them condenser coils and check the fan motor. That is something that is fairly easy to do. Get some coil cleaner from ace hardware and go by directions. Check that fan motor. If it ain't going while the compressor is going that is your problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
True GDM-7... | Answered on Jul 05, 2010
Remove the doors, then the evaporator cover. Just be careful.
True GDM-7... | Answered on May 20, 2009
Jeremy, after the line and new filter drier is put in the high pressure side and silver soldered make sure the unit is placed in absolute vacuum for 30 to 60 minutes. It's critical that all air and moisture is remove and the charge applied on low side with out a single air bubble put back in. You may need some on hands help on this solution to get the cooler working properly, Thanks Sea Breeze
True GDM-7... | Answered on Dec 31, 2008
sometimes the evap has a copper tube that the sensing buld goes into and is very hard to find. The operations manual (found on Parts Town.Com) does not mention it but I have had experiences where you really have to look hard as the hole is less than a quarter of an inch and is sometimes covered with a putty similar to plumbers putty.
True... | Answered on May 22, 2020
Most of the time it's a compressor relay that does this. Your model will most likely have one. Get your model number and check the internet and see if your model has one. They are usually a small black plastic device attached directly to the compressor terminals and take up two of the three terminals. This is under the black plastic cover that is held on by a metal piece or wire, right on the compressor itself. Usually they're only about 10-20 bucks so it my be worth a shot.
True... | Answered on Nov 05, 2019
True GDM-7 Beverage Cooler Logo
21 questions posted
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
jasbo
jasbo
Are you a True Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
True Refrigerators
  • True Refrigerators
Most Popular Question
drinks keep exploding
  • Refrigerators
