20 Most Recent Sennheiser 100/500 G2 Series Wireless Combo Kit EW150ENGG2C Microphone Questions & Answers
This is quite common with G2's, and really annoying!
If you are lucky, 50% of the time the red button is pushed inside the mic.
You need to remove the bottom section:
- open the battery compartment
- there should be 3 star-bit screws around the outside (remove)
- pull the bottom of the mic off
If the red button is not inside, they are available as a spare part from Sennheiser dealers.
Be carefull when putting the mic back together, it needs to line up correctly with the internal guides, forcing the base back on could damage the ribbon cable. when the line-up is correct it slides on very easily.
Best of luck.
PTB
Sennheiser... • Answered on Jul 26, 2018
You should'nt need a scematic, this happens all the time with the ew100 handhelds. you will need to remove the three star bit screws between the screen and the batteries, pull off the end cover and with a small screwdriver or some long needle nose pliers- put the red button back into the hole from the inside of the cover. Just take care when putting the end cover back on- sometimes its a bit difficult.
Goodluck
PTB.
Sennheiser... • Answered on Mar 02, 2015
This sound to me that an electrolytic capacitor has given up and went short circuit especially tantalums it can be a transistor or I.C. but I doubt it
Sennheiser... • Answered on Jun 29, 2014
This isn't a solution. But after I've gotten into my microphone with the same issue using a torx screwdriver I found that I (Electrical Engineer) don't have the proper equipment to fix the issue. Roughly 100 dollars (Flat rate) and a send off to Sennheiser is your best bet.
Sennheiser... • Answered on Mar 01, 2014
Call Sennheiser. They can help you troubleshoot.
Sennheiser... • Answered on Feb 14, 2011
Call Sennheaiser. They can help you troubleshoot.
You'll probably have to send it to Sennheiser USA.
To repair the on/off switch of the handhelt it would cost abt 15 minutes and $2,00 for the switch.
So that would be $20-25.
Reagrds Gerard
Sennheiser... • Answered on Oct 04, 2010
This is probably interference in the wireless connection for the lavalier mic.
Try switching channels to find a clear one!
Or switch to a wired lav mic if that's practical.
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.whamuniversal.com
Sennheiser... • Answered on Mar 08, 2010
The Canon HV20 mini plug audio input has a very limited useful range, but you should be able to adjust your setup to get acceptable results.
Just on a side note, you can get a wired lavalier mic at Radio Shack for $15 that could make the problem go away, or at least eliminate a lot of electronics ... but the cable will only be about 15 feet long ... you could use an extension, just make sure it's mono.
Couple notes: One is that the mini plug input on the HV20 is a stereo microphone input, and you're plugging in a mono source. This will not cause distortion, but is not ideal ... a simple stereo adapter to break down the input (mono mic into one side of stereo adapter, stereo adapter into camera) would optimize the situation.
Another thing is, you have at least two volume controls that absolutely MUST be adjusted correctly ... hopefully one of these is the problem and soon will be the solution.
I don't know the Sennheiser wireless set in particular, but it probably has a volume control on the receiver box (which might be over by your camera) .. the other is actually IN the camera software ... go through the menus and see if you can select audio input volume and try the "auto" setting, and also try the "manual" setting, and when on manual, turn it down. This is the audio input volume control for the camera itself. It is the level that corresponds to the small level meters you can see in the camera's LCD screen ...
Good luck! You are not alone with these issues ... the beauty of modern video cameras is in their small size, but it's also a problem because you are not provided with proper audio inputs - you have to deal with the stereo mini plug input, which is less than ideal.
Sennheiser... • Answered on Mar 06, 2010
Maybe the gain in the receiver is down.
You can adjust the outputgain the menu.
Good luck,
Gerard
Sennheiser... • Answered on Jan 14, 2010
There are different frequencies available and being used in each location.
To get a basic idea of which frequencies are available in your area, try this online tool:
http://www.sennheiserusa.com/findfrequency/
or use the literature provided with the Sennheiser gear (usually a useful chart comes with the wireless gear).
Also, remember that your transmitting frequencies need to be spaced apart a minimum of .400 MHz (or 400 kHz).
Frequency selection shouldn't cause feedback problems though. If you select a frequency for a mic that a local TV station is already using to broadcast, it will cause RF Interference (Radio Frequency). You'll probably hear static noises, pops, or since your Sennheiser has a Squelch feature, just drop-outs in audio.
So first consult the available charts to find a set of frequencies that should be available in your area. Then, if one of your mics is experiencing such an issue, try moving it .400 MHz to the nearest unused frequency and see if the RFI goes away. Repeat until the RFI no longer manifests.
Sennheiser... • Answered on Jul 15, 2009
You might want to check the other end as well. Take a ohm meter and check the wires to make sure their is a reading on both.The wire you speak of is called shielded cable and there should be no reading between the sheilding and the center conductor when they are seperated from the capsule. If there is a reading you have a short.To clarify, the outer sheild should read at or near zero when you check @ each end as should the center conductor ( the white ) wire.There should be no reading between the two (the sheild and the white) when they are unhooded @ each end. Also when the capsule is unhooded you should get a reading between the two terminals, if not the capsule is open and needs replacement.
Sennheiser... • Answered on May 06, 2009
Try adjusting your squelch level, it should be no higher than 05 or 10. If a higher squelch level is required it means you are on an active channel and need to change to another free on.
for any of you as unlucky as i to have to use these onstage..(ok their fine we just have the wrong mics) a piece of tape over the mute button on top of the unit...they have a tendency to get knocked into mute position mid song...
on Jan 30, 2009 • Sennheiser 100/500 G2 Series...
Tip
Hello Timothy, the microphone has a 3.5 mm connector, which has a thread, you must unscrew this thread and you should be able to exit Discuss the type of connector you have I hope you can solve the problem Greetings Franco Dosil Hola Timothy, el microfono tiene un conector de 3,5 mm, que tiene una rosca , debes desenroscar esta rosca y tendria que poder salir Comenta el tipo de conector tiene Espero puedas resolver el problema Saludos Franco Dosil https://assets.sennheiser.com/global-downloads/file/8949/SK_100_G3_Manual_12_2016_EN.pdf
Sennheiser Audio... • Answered on Jun 21, 2019
Hi David, comment that cables are wrong in the transmitter, to try to find the best possible solution I wait your answer Greetings Franco Dosil Hola David, comenta que cables estan mal en el transmisor, para tratar de encontrar la mejor solucion posible Espero tu respuesta Saludos Franco Dosil https://www.fullcompass.com/brand/sen-sennheiser/replacement-parts https://en-us.sennheiser.com/accessories http://www.hifiheadphones.co.uk/spares-accessories/sennheiser-spares.html?currency=EUR&dir=desc&limit=5&mode=list&order=name
Sennheiser Audio... • Answered on Jun 07, 2019
22 questions posted
Top Sennheiser Audio Players & Recorders Experts
Marvin
Marvin
Vernon Taylor
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sennheiser Audio Players & Recorders
Most Popular Question
batteries hot
  • Audio Players & Recorders
